Forums › The Car › 206 Talk › 206 gti 180 gearbox |
Posted: Thu May 10, 2012 10:37 am |
depends on how much money you got.
gear ratio wise you can only have top speed or acceleration; can't have both
Posted: Fri May 11, 2012 2:56 am |
what would you advise for top speed??
Posted: Fri May 11, 2012 5:09 am |
More power.
Posted: Fri May 11, 2012 5:20 am |
just fit a smaller crown wheel from gti
Posted: Fri May 11, 2012 7:33 am |
I think the GTi 180 should of had a 6 speeder as standard, too revvy on the motorway!!
Posted: Fri May 11, 2012 7:57 am |
It's not a motorway car.
