Online Now [530]:
Visitors: 529
Today: 117516
Total: 145596532
Forums › The Car › 206 Talk › change pedals?
change pedals?
Forum Index › 206 Talk
danlouiee
PostPosted: Fri May 11, 2012 1:08 pm Up
Basically, i have a set of SP pedals and a matching foot rest plate to fit to my car. Instead of Tigersealing or drilling my current pedals i thought i could use my GTI pedals that i have had lying about for ages and put the SP parts on the pedals and fit them.
would this be an easy thing to do or is it more hassle than its worth?
PostPosted: Fri May 11, 2012 1:21 pm Up
So you want to change the pedals over just so you can fit the SP pedals? Sounds like a lot of hassle to be honest much easier to just fit them on the the pedals you have in the car already.
Foot rest is easy to fit 4 self tappers no need to drill or use tiger seal on that one.
danlouiee
PostPosted: Fri May 11, 2012 1:35 pm Up
yeah your right mate, i think im just gonna put the foot plate in as i have the self tappers and then just sell the pedals as i can be dealing with trying to bond them and it not holding if you get me or drilling my current pedals.
PostPosted: Fri May 11, 2012 1:45 pm Up
I drilled mine without any problems and they do make a difference to the interior, don't give up without even trying
danlouiee
PostPosted: Fri May 11, 2012 2:02 pm Up
did yours not come with them as its an XSI? which method did you follow?
PostPosted: Fri May 11, 2012 2:24 pm Up
Nope I fitted mine and drilled them
danlouiee
PostPosted: Fri May 11, 2012 2:28 pm Up
did you drill the rubber or drill the metal on the pedals after you removed the rubbers?
Lecktorious
PostPosted: Fri May 11, 2012 2:30 pm Up
Trade Rating: +59
No point in drilling through the rubber and ruining a set of pedal covers.
Take them off and drill them. Might be tight for space, but it shouldn't be a biggie.
'98 Nile Blue 306 GTi 6
PostPosted: Fri May 11, 2012 2:45 pm Up
Yeah remove the rubber and as said it is a bit tight but it's all good. If you can get hold a drill adaptor so that the drill can drill at right angles that would make it easier.
