Latest: tbafonso
Overall: 17130
Online Now [801]:
Visitors: 800
Today: 107939
Total: 102683842
Forums › The Car › 206 Problems › airbag light flashing
anton1989
PostPosted: Sat May 12, 2012 3:06 pm Up
Trade Rating: +16
Been out allday in my car, including some motorway driving, on my home the airbag light started flashing, what could this be?
I turned the ignition off the started it again the light came on and went off like normal then after about 2 minutes of driving the light started flashing again?
it's a y reg 1.1
thanks in advance
Walton450
PostPosted: Sat May 12, 2012 3:25 pm Up
mine did the same, i just disconected the battery and left for a few mins and when i re conneced it had gone.
I\'m Steve got a 2003 verve.
devildriverxii
PostPosted: Sat May 12, 2012 3:30 pm Up
Has happened to me twice now, both times I had to change the clock spool thing under the airbag.
2002 1.6 5dr Black Edition.
anton1989
PostPosted: Sat May 12, 2012 3:43 pm Up
Trade Rating: +16
will give this a try, cheers
anton1989
PostPosted: Sat May 12, 2012 3:44 pm Up
Trade Rating: +16
whats the clock spool? Under which airbag? Steering wheel or dash
iainlovatt
PostPosted: Sat May 12, 2012 4:33 pm Up
Could be a loose coonection in the fuse box, makes Seneca if it comes on and off, have a look tomorrow it's a orange cable just make sure it sitting well
Its next to the fuse box box on drivers side.
(My Garage)
anton1989
PostPosted: Sat May 12, 2012 5:19 pm Up
Trade Rating: +16
yeah it could be that because I done a dashboard change awhile ago, will check tomorrow cheers
devildriverxii
PostPosted: Sat May 12, 2012 5:25 pm Up
Mine was under the airbag on the steering wheel.
anton1989
PostPosted: Mon May 14, 2012 1:16 pm Up
Trade Rating: +16
Still have this problem? Would the wire that goes on the seat belt behind the rear card (on a 3dr) make this happen if it was faulty or somthing?
tinytoontown
PostPosted: Mon Jul 02, 2012 5:48 am Up
Miine does this too, doesnt seem to have any obvious reason for it, some times it flashes, onther time it wont...
Only had the car a few weeks so not sure where to start, I have the MOT coming up in a month or so,
If it is flashing at time of MOT - Will it FAIL ?
Tiny, proud owner of a 2000 Peugoet 206 Style 1.1 (X reg) in Bottle Green
PostPosted: Mon Jul 02, 2012 5:50 am Up
YES.
It also wont deploy in the event of an accident if the light is flashing / on all the time.
A 206 of this age its most likely the rotary spool gone faulty BUT without testing the srs system your not going to get a 100% concrete answer.
tinytoontown
PostPosted: Mon Jul 02, 2012 7:13 am Up
thanks for the info
so.. this spool... is that expensive and hard to change ?
where do i get a new one?
PostPosted: Mon Jul 02, 2012 3:46 pm Up
tinytoontown wrote:
thanks for the info
Steering wheel needs to be removed.
New one from Peugeot OR get a good second hand one from Ebay / scrapyard etc.
BUT until the cars srs system is scanned we havent got a clue what the fault really is.
