Online Now [644]:
Visitors: 643
Today: 232984
Total: 146687852
Forums › The Car › 206 Talk › Jacking up
Jacking up
Forum Index › 206 Talk
andyleep
PostPosted: Sun May 13, 2012 1:49 am Up
Where are the best places to jack up the 206 GTI 180? A normal 206 is easy to use the rear beam but can't see a good spot on the 180 as the rear suspension is different. And the front? I am referring to when using a hydraulic jack, not the peugeot one. Thanks
iainlovatt
PostPosted: Sun May 13, 2012 2:08 am Up
i always use the sills buddy! then some axle stands under the axles! Smile Very Happy
(My Garage)
PostPosted: Sun May 13, 2012 2:16 am Up
Don't use the sills. You'll ruin the underseal and crush them eventually. That's a massive load on a tiny area,
Drive onto some blocks of timber and use the front subframe - with some timber between jack head and subframe to spread the load.
If you just want to lift one side use the box section under the floor. There is a big wide one under the front floor closest to the wheel and it runs along the side half the length of the floor..
To lift one rear wheel a trolley jack under the rear damper mount on the trailing arm is fine to use.
usher
PostPosted: Sun May 13, 2012 2:17 am Up
i use the subframe for the front, rear wishbone bolt
for the rear axel mount
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
andyleep
PostPosted: Sun May 13, 2012 6:22 am Up
Yep, don't want to use the sills, they bend easily and crumble!
PostPosted: Sun May 13, 2012 7:01 am Up
I concur, a tyre place did this to mine and crushed it Sad Only noticed a couple of weeks later so couldnt take it back and moan Crying or Very sad
