Latest: ArtistKS
Overall: 17145
Online Now [67]:
Visitors: 66
Today: 9631
Total: 115998119
Forums › The Car › 206 Talk › clutch slip
clutch slip
Adam2061994
PostPosted: Wed May 16, 2012 7:32 am Up
my clutch has been slippng a lot lately at high gears in high revs and it seems to be fine in 1st gear, but i want to make the most out of my clutch until im paid for the month dont want it giving in on me, has anyone got any suggestions so i can make the most out of it, good tips?
206 1.6 owner
PostPosted: Wed May 16, 2012 7:34 am Up
Dont drive it unless you absolutly have to. Avoid changing gear as much, no traffic light grand prix's.
Adam2061994
PostPosted: Wed May 16, 2012 7:37 am Up
thing is i have to use it a lot lately, any good techniques that i could do like releasing clutch quickly or slowly?
206 1.6 owner
Big_Rich180
PostPosted: Wed May 16, 2012 7:43 am Up
Change gear without the clutch lol, its a pain in the a**e though.
PostPosted: Wed May 16, 2012 7:45 am Up
It's not that hard, I drove the GTi around for 3 weeks with no clutch when the thrust bearing went through the pressure plate, was a b***h to parallel park though, and I dont think I did the starter motor any good.
clutch on the MA box should last for ages
Adam2061994
PostPosted: Wed May 16, 2012 7:57 am Up
well it just seems to be slipping now in 2nd gear if i put a little more acceleration, first is fine but second it goes mad if i put my foot down ha so il jsut propper be smooth to accelerate and how do you drive with no clutch you cant select gear and engage it? :/
206 1.6 owner
Big_Rich180
PostPosted: Wed May 16, 2012 8:00 am Up
It will engage a gear at a certain rev point.
PostPosted: Wed May 16, 2012 8:01 am Up
And on downshifts, blip the the throttle before moving down a gear.
Adam2061994
PostPosted: Wed May 16, 2012 8:02 am Up
ah right i see, bet u have fun switching gears tho haha!
206 1.6 owner
Adam2061994
PostPosted: Wed May 16, 2012 8:07 am Up
blip what you mean?
206 1.6 owner
PostPosted: Wed May 16, 2012 8:11 am Up
Lift off the throttle, pull it in to neutral put your foot on the throttle for a second or 2 to bring the revs back up and then select the gear.
Adam2061994
PostPosted: Wed May 16, 2012 8:13 am Up
is that when i have no clutch?
206 1.6 owner
PostPosted: Wed May 16, 2012 8:19 am Up
You can do it now to save using the clutch for gear changes.
adam_w_1
PostPosted: Wed May 16, 2012 9:05 am Up
-Avoid hard launches,
-avoid bogging down your car (e.g. trying to pull from 30mph in 5th),
-try where possible no to park facing uphill,
-try to limit the weight you're carrying in your car,
-try to avoid full throttle (not sure whether your 206 is a diesel or petrol 1.6, but this is particularly the case in a diesel where peak torque will be more than enough to rumble the standard clutch!)
206 1.6 hdi 110:\r\nStage 1 remap to 140bhp + 220lbft
