Online Now [701]:
Visitors: 700
Today: 2262
Total: 145481807
Forums › The Car › 206 Problems › Gearbox??
Gearbox??
GingeWrexham
PostPosted: Wed May 16, 2012 1:54 pm Up
Hi guys. Just after some info. Been finding it hard 2 get into gear lately. Then got home tonight and it feels like the whole gearbox has gone, can't get it in any gear. And when it's in the neutral position I tried pushin it back and it was like it was still in gear! Is it the gearbox? Or possibly somethon else? Thanks for your time
2002 206 GTI
PostPosted: Wed May 16, 2012 1:55 pm Up
Will it go into gear with the engine off?
GingeWrexham
PostPosted: Wed May 16, 2012 2:00 pm Up
No mate and it's been makin a racket 4 a while now from the box
2002 206 GTI
James_sinovi
PostPosted: Wed May 16, 2012 3:22 pm Up
If you haven't already, then check the linkages between the gear stick and box. The joints can wear over time or even pop off causing problems.
pug206lx
PostPosted: Wed May 16, 2012 3:45 pm Up
Im going with linkages as well, there's 3 behind the engine. I suspect the top one has popped off...
GingeWrexham
PostPosted: Thu May 17, 2012 12:06 am Up
Would that cause a rattling behind the wheel? It sounds like a helicopter takin off behind my wheel
2002 206 GTI
johnuk
PostPosted: Fri May 18, 2012 9:35 am Up
could be the gear plate need changing
my gti problem
