Latest: Kifi69
Overall: 17183
Online Now [395]:
Visitors: 394
Today: 81843
Total: 143630502
Forums › The Car › 206 Talk › 206 HDi running temperature?
Scrumpy
PostPosted: Thu May 17, 2012 8:43 am Up
My 2003 2.0 Hdi once warmed up has a steady engine temp of 70 degrees. Halfway up the scale would be 90, what's the normal running temp that you folk are experiencing?
206 SW 2.0 HDi
PostPosted: Thu May 17, 2012 9:04 am Up
Mine runs at 70 spot on. But I have a FMIC.
lenbt
yep mine's similar, day to day. the highest ive seen it was at 90 after a few hours driving.
lmilligan
PostPosted: Thu May 17, 2012 9:15 am Up
Mine runs about 80
PostPosted: Thu May 17, 2012 9:36 am Up
water or oil?
Abzynthe
PostPosted: Thu May 17, 2012 9:42 am Up
East Area Rep - Abzynthe
Both my temp guages sit at 80 after about 5 minutes and dont go any higher.
PostPosted: Thu May 17, 2012 10:02 am Up
i always got 80 for water and 100 for oil
lmilligan
PostPosted: Thu May 17, 2012 10:43 am Up
Damn I only have one gauge.
PostPosted: Thu May 17, 2012 11:11 am Up
Mine sits at 80 on both
Scrumpy
PostPosted: Thu May 17, 2012 1:45 pm Up
Water. Cheers for the replies, guess it's just fine then
206 SW 2.0 HDi
Jaeger
PostPosted: Sat May 19, 2012 3:47 pm Up
Mine seems to sit at 70* most times but can go up to 90* (and no more) when on the motorway.
This seems normal.
I believe I have a dual indicator at ignition it tells you the oil level after 20-30 seconds it shows coolant temp.
At least that what I was told, when I first got it I though it had a problem as the arrow jumps up on start up! Surprised Laughing
2001 Peugeot 206 2.0 HDi 90 D TURBO in China Blue (98-01) [57 MPG]
Spiky
PostPosted: Mon May 21, 2012 12:51 am Up
mines a tad under 80 too
FYI, having a FMIC has nothing to do with the water temp on the car Very Happy
206 HDI Dturbo X/2000
PostPosted: Mon May 21, 2012 1:26 am Up
Why has it lowered since fitting the FMIC then? IIRC it was around the 80mark. Now it never raises above 70, unless stuck in traffic, on a hot day.
(Not in an argumentative way, just curious.)
rlees85
PostPosted: Fri Jul 12, 2013 3:43 pm Up
Sorry to raise this from the dead... what is normal for stuck in traffic on a hot day like today? mine was pushing 100C at one point. Fan was not running (and it does work in PP2000!)
Is it normal? Never had a car go above 90 before.
