Online Now [145]:
Visitors: 144
Today: 33396
Total: 138768632
Forums › The Car › 206 Problems › Instrument cluster lights
andyleep
PostPosted: Fri May 18, 2012 2:27 pm Up
Right, I have no oil light on my dash. So I took the cluster out hoping there would be seperate bulbs for the warning lights (as it has been with all cars I have owned before). But no. Is it all LED's built into the circuit board? Can these be changed? I did notice there are several torx heads on the back holding the printed circuit in, but didn't have time to undo them tonight. Anybody changed the individual bulbs before or is this not possible? It is a 55 plate GTI 180
PostPosted: Fri May 18, 2012 2:43 pm Up
The LED's can be changed. Many people have changed the colour of the lights on the dash. There will be a thread somewhere how to do it, but can't be bothered to search for it..
PostPosted: Fri May 18, 2012 4:01 pm Up
there's NOTHING wrong with it!
Multiplexed 206s are not programed to show the low pressure oil warning light at the pre start check.
Do an actuator test with Peugeot Planet if you want to test the system.
