Latest: airmastertapes
Overall: 17133
Online Now [318]:
Visitors: 317
Today: 42477
Total: 106706642
Forums › The Car › 206 Problems › 206 AirBag Light - How to Switch off?
Go to page Previous  1, 2
PostPosted: Sat May 19, 2012 1:49 pm Up
Uz wrote:
Take the clocks apart and tape over both of the airbag lights from the inside and also disconnect your mfd if it's one of the one where airbag fault come up before you go back in, always reconnect mfd afterwards.
airbag light not working is also an instant MOT failed Laughing
QuArTz
PostPosted: Sat May 19, 2012 2:10 pm Up
Trade Rating: +16
The airbag light must come on briefly on ignition and then turn off to pass MOT
Something to keep in mind, if you need to buy a new airbag ECU, is that the serial numbers MUST match up identically to the ones in your vehicles airbag ECU.
Also the airbag ECU MUST be from the same 'plex' as yours and obviously not from a donor vehicle which has been in the slightest accident as the seat belt pre-tentioners may have fired and they arnt such an obvious fault as the airbag themselves.
PostPosted: Sat May 19, 2012 3:16 pm Up
mcburney777 wrote:
lol yes its switched of. tried plenty of things, still no joy, is it hard to take the clocks apart?
IF that switch is in the position off off thats why the lights on.
PostPosted: Sat May 19, 2012 3:53 pm Up
No its not thanks to another VOSA c**k up Rolling Eyes
T18sty_206
PostPosted: Sat May 19, 2012 4:06 pm Up
Just take the bulb out to get it through then deal with the problem afterwards? The seat belts are also linked to this btw because when i took my rear belts out my airbag light kept flashing.
PostPosted: Sat May 19, 2012 4:10 pm Up
The rear seatbelts on a 206 are NOT linked in to the srs system.
fatboyslim
PostPosted: Sat May 19, 2012 4:30 pm Up
Why WTF have VOSA done now??
Yes I own a CC and I'm neither gay or a hairdresser!!
mcburney777
PostPosted: Tue Jun 05, 2012 12:19 pm Up
hello all again!
update here, after many attempts at various short cuts that didnt work i went and got the car scanned and it read a fault in the slip ring.
im going to source myself one tomoro - either that or a new com2000 unit (i think thats wot its called)
are either of these easy to install? i dont even know how to take the steering wheel of lol
chris
PostPosted: Tue Jun 05, 2012 3:17 pm Up
Rotary switch if the car is NON multiplexed.
Com2000 unit if it is multiplexed.
Whichever it is the steering wheel needs to be removed.
Check what eletrical system your 206 uses as 2001 is the cross over year BEFORE buying a replacement part!
mcburney777
PostPosted: Wed Jun 06, 2012 6:31 am Up
thanks for your help thus far.
my car is a multiplex i have sourced a new comms for £50, (2nd hand)
is the steering wheel etc hard to remove?
and also would the light extinguish itself upon the comms being replaced or will i have to go get it reset?
chris
PostPosted: Wed Jun 06, 2012 7:42 am Up
If the light is on due to a genuine airbag fault once it is fixed it should go out itself. If it's on due to a deployed airbag then it will need to be reset.
PostPosted: Wed Jun 06, 2012 8:05 am Up
Correctly shut the BSI unit down & disconnect the battery.
Airbag is held on with a spring clip, feel the back of the bottom spoke on the steering wheel, insert flat blade screwdriver through it then push the clip upwards to release the 2 airbag spring clips.
Torx 50 / 55 ( cant remember which ) screw in middle of steering wheel holds it on.
Undo it slightly a couple of turns but DONT remove it yet, smack the back of the steering wheel towards you to free it from the splines, then you can remove the bolt.
If the bolt is fully removed before the steering wheel is smacked free of the splines you risk ripping the com wires out & / or smacking yourself in the face with the steering wheel when it breaks free, both have been done before on here Rolling On The Floor Laughing
mcburney777
PostPosted: Tue Jun 12, 2012 11:39 am Up
Update - many thanks for all your help guys. the instrusctions on how to replace were perfect.
all is well now the problem is cured and the airbag light is finally off.
note tho - at the mot re test he did make me switch the engine of and then switch it back on again to see tjhe light was working so simply removing the bulb etc will not work!
thanks guys
chris
Page 2 of 2
