Latest: Kifi69
Overall: 17183
Online Now [502]:
Visitors: 501
Today: 41179
Total: 144332777
Forums › The Car › 206 Problems › P2408 P0122 P1471 P1351 codes
darratt78
PostPosted: Sun May 20, 2012 10:05 am Up
Hi, ive used Planet to diagnose EML faults on 1.6 hdi. Im aware that P2408 is fuel cap sensor/harness, which I need advice on if its worth changing and how, Ive cleaned DPF and pieced back together, but I have P1351 Glow plugs or relay, and P0422 max number of aborted re-gens, and P1445 Quantity of additive too high! Im thinking of first changing the throttle position sensor as they are cheap, just dont know if its inside or outside the car?! Then doing the glow plugs before resetting the values with Planet then forcing a re-gen? I know the glow plugs are important to the re-gen process but didnt know if they are essential? The car starts first click. Idle is a little erratic/lumpy when cold (but not everyday). Or any advice on procedure to test the Throttle Pos Switch/glow plug relay/glow plugs with Planet? I would love to get the EML light out but too many codes at the mo!
206 hdi GTI
darratt78
PostPosted: Sun May 20, 2012 10:06 am Up
[img]
[/img]
206 hdi GTI
darratt78
PostPosted: Sun May 20, 2012 10:07 am Up
[img]
[/img]
206 hdi GTI
