Latest: tbafonso
Overall: 17130
Online Now [130]:
Visitors: 130
Today: 32779
Total: 104564571
Forums › The Car › 206 Problems › Replacement headlights
sulli
PostPosted: Sun May 20, 2012 10:09 am Up
Im wanting to get some angle eye headlights but most of the ones I have seen have the separate high low beam bulb I believe but my standard light has one 1? With both built in. Will I need some sort of harness to convert it to double? Thanks
206 VAN SILVER!
www.Sheffield-WebDesigns.co.uk - discount for 206info members!!
www.HealthyCigs.co.uk - discount for 206info members!! quote - 206info
Antknee
PostPosted: Sun May 20, 2012 10:15 am Up
You can get an adaptor for the wiring, if its a preplex model you can just change the stalk in the car or you can just get some H4 angel eyes
sulli
PostPosted: Sun May 20, 2012 10:21 am Up
it's 02, so im guessing its multiplexed?
206 VAN SILVER!
PostPosted: Sun May 20, 2012 11:45 am Up
Have you got crystals or frosted headlights?
Being a 02 doesn't mean you have a multiplex as I believe they changed around that sort of time.
sulli
PostPosted: Sun May 20, 2012 11:53 am Up
I have the frosted, there's 3 bulbs, sidelight, beam, and indicator. But the steering wheel is the newer style so i think its multiplex? but i thought the headlights were crystals for multiplex? thanks.
206 VAN SILVER!
PostPosted: Sun May 20, 2012 11:56 am Up
Sounds like you have a cross over version and you may be lucky to have the H7 connectors already on the car.
If you have you shouldn't have to worry about the adaptor for the changing the lights, if you have I think you may only just need a BSi update to make them work.
sulli
PostPosted: Sun May 20, 2012 12:04 pm Up
ok cool, ill have a look tomorrow, also how much are bsi updates generally? if i havn't got the connection will i still be able to get the headlights to work with adaptors? Thanks
206 VAN SILVER!
PostPosted: Sun May 20, 2012 12:08 pm Up
£8 for the 2 grey H7 connector plugs & 6 pins from any Peugeot / Citroen main dealer if your 206 doesnt already have them.
PM Lee as he is in Sheffield & can tweak your BSI configuration set up much cheaper then a Peugeot main dealer Wink
