Latest: jackrox1992
Overall: 17186
Online Now [364]:
Visitors: 363
Today: 133618
Total: 148503408
Forums › The Car › 206 Problems › Knock & Crack Noises
myke
PostPosted: Sat May 19, 2012 2:57 am Up
Hiya, so Ive had a search and I cant find anything remotely similar... Maybe Im searching with weird terms. So, I had a knocking noise when going over bumps etc. The wheel baring was replaced and the knocking calmed down, wishbones etc were all checked during MOT and its all ok. The other day in traffic I noticed that when I bring up the clutch, as it gets into gear there's a knock, when I change gear and bring the clutch back up it knocks again. It seems to mainly do that in 1st and 2nd, I then noticed when its in gear, if I acellorate and take my foot off the acelorator quickly then there's a knock, it also knocks when the car is reversing slowly, and sometimes when going over bumps... Its strange, it all sounds like the same knock. Im going to check the engine mounts and gearbox mount I think, could it be either of them?
Ive also noticed recently that my clutch pedal sometimes "cracks" when I push it down. It doesnt happen very often, yesterday it cracked, the pedal then had no like, force trying to return back to its normal position, I took my foot off the clutch and it stayed 'down' but then sprung back up to its original position, it didnt affect the control of the car or anything..
Any ideas? Im assuming its two separate problems.
Martind
PostPosted: Sat May 19, 2012 7:48 am Up
Sounds like engine mounts.. Knocking when changing gear
Not sure about the clutch problem though
myke
PostPosted: Mon May 21, 2012 6:59 am Up
Cheers Martin, I'll take a look at the mounts.
martinius88
PostPosted: Mon May 21, 2012 8:43 am Up
Yeah sounds like the exact problem I had engine mount, the rear lower mount, i believe the part number I used was PUG301B but this is an uprated one, by vibra technics these can be picked up for under £30. The clutch cracking sound I cant help with im afraid.
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454
myke
PostPosted: Mon May 21, 2012 10:50 am Up
Awesome, thank you. I'll give it a look.
