Latest: cogeim7
Overall: 17185
Online Now [618]:
Visitors: 618
Today: 17115
Total: 147752763
Forums › The Car › 206 Talk › OBD advice
OBD advice
Forum Index › 206 Talk
sicskate
PostPosted: Mon May 21, 2012 3:43 am Up
Trade Rating: +13
I've attempted to plug my 307 1.4 hdi into a diagnostic, but it's showing 0volts from the port?!?
Does anyone have the wiring diagram for the OBD?
Also with a multi meter I'm getting 14v from 6of the 8 pins so 2 of them are showing no power, is this correct?
Many thanks
Ben
307 1.4hdi Smile
PostPosted: Mon May 21, 2012 11:15 am Up
Could be your code readers kurput!!
PostPosted: Mon May 21, 2012 11:57 am Up
Only 2004 onwards built diesel's will be EOBD compatible.
sicskate
PostPosted: Mon May 21, 2012 3:11 pm Up
Trade Rating: +13
What's the point in having an OBD port then?
307 1.4hdi Smile
PostPosted: Mon May 21, 2012 4:31 pm Up
without that port how on earth you can get a code read? Confused
sicskate
PostPosted: Mon May 21, 2012 11:57 pm Up
Trade Rating: +13
Confused :S
I have an OBD port, but the car isn't EOBD compatible as its a late 2003?
307 1.4hdi Smile
PostPosted: Tue May 22, 2012 1:36 am Up
The pin protocol doesn't match those required for an EOBD device. PP2000 is probably the only thing that will connect to your car.
The obvious reason as to why you have the port is that rather than make a separate part for the petrol and the diesel, it is cheaper for the manufacturer to make one part that will fit both, knowing that the following year they would need to fit it as standard anyway.
sicskate
PostPosted: Tue May 22, 2012 3:20 am Up
Trade Rating: +13
I understand now Sad
So how do owners go about mapping?
307 1.4hdi Smile
gazza82
PostPosted: Tue May 22, 2012 5:44 am Up
They get a specialist to do it with the proper kit. It's not really a DIY option.
sicskate
PostPosted: Tue May 22, 2012 8:10 am Up
Trade Rating: +13
Thats the issue, I booked a mobile mapper but it wouldn't connect to his software.
307 1.4hdi Smile
PostPosted: Tue May 22, 2012 8:55 am Up
If it's any help, I've just plugged into a 'Y' reg diesel 206 using the ELM327 lead and Palmer Performance Engineering software. It connected to the vehicle without any issues and read the codes.
The mobile mapper might have to change some settings to get his equipment to connect, but personally if he couldn't sort it first time, I'd steer well clear as he might end up doing more harm than good.
PostPosted: Tue May 22, 2012 8:58 am Up
My EOBD scanner has read fault codes / put the diagnostic light out on a year 2000 Pug 306 HDI.
BUT
I've also tried it on a year 2001 Citroen Berlingo HDI & it wouldnt even connect.
Its just the luck of the draw if you aint got the recommended kit Laughing
