Latest: Stu-mill
Overall: 17131
Online Now [325]:
Visitors: 324
Today: 33251
Total: 104842101
Forums › The Car › 206 Problems › Help :(
Help :(
Go to page Previous  1, 2
gaffa786
PostPosted: Tue May 22, 2012 2:38 pm Up
Seabook wrote:
did you check the air filter?
then coilpack and plug if there is misfire...
or just call AA and let them deal with it
I tried to open the air filter but couldnt find the right screws in my car so im just leaving it for a little bit to hope it drys out. Knowing my luck something else will mess up
Ste
PostPosted: Tue May 22, 2012 2:42 pm Up
Staff - Ste
If you've got a cone filter then make sure thats not soaked, or like others have said check your air filter, coilpack also check if your alternator was soaked as I've seen cars act up from people hosing the engines which lead to their alternator not working as it should.
The Cars:
Andy_
PostPosted: Tue May 22, 2012 4:20 pm Up
Hope it works for you but that was kinda stupid
Progress Thread
Jensen
PostPosted: Wed May 23, 2012 12:50 am Up
Sounds like you've deffinatly got water in your engine,
Happened to mine a month or so ago ended up having to change my spark plugs, coil pack, oil, oil filter and air filter, also took the whole filter to pieces and dried it out, including the 3 air sensors, check your rocker cover aswell see if it's milky, the top of mine was from the water that had got into the engine, took all that appart gave it a clean and it's ran spot on since with no problems! Smile
PostPosted: Wed May 23, 2012 3:25 am Up
Seabook wrote:
don't tell me you are using high pressure water spray to clean the engine bay lol
I do on the counter balance forklifts when I service them BUT then again the electrical installation under there is a lot more water proof then used on a car Laughing
I wouldnt be stupid enough to use a pressure washer under the bonnet of a car Rolling On The Floor Laughing
gaffa786
PostPosted: Wed May 23, 2012 7:51 am Up
It is working fine now thanks people. I think all the water has gone and it seems to be running like normal now
Thanks. There should not be anymore stupid problems in a while Smile
Page 2 of 2
