Posted: Wed May 23, 2012 9:08 am |
Does anyone know of anywhere that there is a list or table that compares the various equipment specs of 206 models?
I'm thinking of something similar to brochures you see with all the models listed across the top and then a table containing dots, indicating which items are original equipment or options on the various models
I'm looking at a variety of 2.0 HDi models at the moment and would be good to know what real world differences there are between SE, Sport, XSi and god knows how many other different models before travelling to view
Something like 2004/2005 vintage if that helps
Matt
Posted: Wed May 23, 2012 9:24 am |
Posted: Wed May 23, 2012 9:31 am |
That's pretty good thanks - just need to trawl through each model and see the differences
It just seems to confirm that there's very little difference in spec terms between Sport, XSi and DTurbo apart from the year they were made
Posted: Wed May 23, 2012 9:32 am |
Yeah there's insnt that much difference, maybe just the colour of the trim ect. Mines a quiksilver but it has all the bits a gti has.
Posted: Wed May 23, 2012 9:46 am |
Iv got the XSi and that's got pretty much what the GTi has apart from leather, gloss black wing mirrors, and the digital air con.
Mines a 04 as well one of the last XSi before they changed them to the sport spec. I think some of the sport specs didn't come with the multiline dash display as well.
Posted: Wed May 23, 2012 10:21 am |
| Now a 2010 Renault Megane Coupe owner | |
Posted: Wed May 23, 2012 10:45 am |
I've got sport spec, digital climate control etc, as mikey said mine didn't come with multiline display.
Posted: Wed May 23, 2012 10:48 am |
devotedsniper wrote: |
http://www.parkers.co.uk/cars/reviews/peugeot/206/hatchback-1998/equipment/
Parkers have that sort of thing for more models on there site. |
What he said.
Parkers have exactly what you are after.
Posted: Wed May 23, 2012 11:26 am |
Did Sport models come with auto wipers?
Posted: Wed May 23, 2012 11:31 am |
Edward wrote: |
Did Sport models come with auto wipers? |
Not sure my XSi has both auto wipers and auto lights
Posted: Wed May 23, 2012 3:31 pm |
Martind wrote: |
What he said.
Parkers have exactly what you are after. |
Be warned a lot of the information on Parkers for car specs is actualy WRONG
Posted: Wed May 23, 2012 4:45 pm |
Thanks everyone
Parkers is okay, but not particularly specific with regard to things like auto-wipers etc
The other link is okay too, just takes a lot of trawling through
Seems to be the DTurbo was around to 2004/04 when the range changed to include the Sport model - the 2.0 HDi Sport is broadly speaking the 'new' DTurbo
XSi was there before and after 04 until 05 reg as far as I can see.....as from 55 it disappeared....
Then you throw in the DAC/CC models of all the above versus the non-DAC......????
I think I'm no further forward
I think I should just pick a car that I like, whether it be DTurbo, XSi, Sport....or even SE !!!
Posted: Thu May 24, 2012 1:34 am |
DAC is just climate control by another name
SE is the later spec with all the toys & it also has a locking glove box
Posted: Thu May 24, 2012 1:53 am |
Trade Rating: +59
Dturbo > XSi > Sport
Then they introduced the HDi GTi
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Thu May 24, 2012 2:26 am |
Lecktorious wrote: |
Then they introduced the HDi GTi  |
Not quite - the XSi was around at the same time as the Dturbo AND the Sport but discontinued with the 05 reg.....although I'm sure there's the odd one around on a 55 plate or later that was registered late but built earlier
The Sport seems to be the replacement for the DTurbo from the 04 reg onwards
To be fair, quite what the real world differences are between the three of them are probably completely minimal!!
GTi only comes with the 1.6 HDi engine.......which would have been my choice on paper......until I read into it a bit deeper!!
