Latest: cogeim7
Overall: 17185
Online Now [546]:
Visitors: 545
Today: 85980
Total: 147213053
Forums › The Car › 206 Problems › A lot of oil around rocker cover
Go to page Previous  1, 2
nemesislee
PostPosted: Thu May 24, 2012 11:47 am Up
I'm sure that I shouldn't be able to see the pistons? Inside, shouldn't they be covered by the baffle plate?
What are the problems with it missing?
AvHh this is doing my tree in
peugeot 206 silver 1.4ltr lx
nemesislee
PostPosted: Thu May 24, 2012 12:11 pm Up
Help please Smile
ramigojag
PostPosted: Thu May 24, 2012 1:06 pm Up
there not the pistons but i dont think there's anything wrong with that and to remove the rocker cover on those engines i think you need to remove the coil pack
nemesislee
PostPosted: Thu May 24, 2012 3:30 pm Up
Had a look and from the Haynes all I can see is that I need to remove the HT lead I think it was called that. But in the Haynes it has the splash plate meaning you can't see inside the gasket. Would it cause any problems if it wasn't there.?
PostPosted: Fri May 25, 2012 2:13 am Up
what is your engine code,is't KFW?
nemesislee
PostPosted: Fri May 25, 2012 3:49 am Up
Il have a look its the chasis number aint it?
PostPosted: Fri May 25, 2012 1:28 pm Up
the chasis number will work Very Happy
Johnbyron
PostPosted: Sat May 26, 2012 6:10 am Up
I've taken my rocker cover off my little 1.2 corsa so many times it's unreal due to breather hoses always clogging up, ( common fault ), anyway on that it was just a case of removing the wires that atatch to the coil pack then undo two studs in the top of the coil pack and pull the coil pack from the spark plugs then unclip any pipework that is attached to the rocker cover and move them out the way and finally slip out all the bolts holding the rocker cover down, really easy job and I know mine was a corsa but still most rover covers are just as easy to take off as another, obviously just stick to the basics of removing coil pack, breather pipes and bolts, simple Smile
nemesislee
PostPosted: Sun May 27, 2012 1:53 pm Up
All sorted now Smile managed to get someone to lend me a torque wrench Smile unbelievable how easy a job it was. Thanks to people who replied in helping me
Page 2 of 2
