Latest: Beduff1977
Overall: 17134
Online Now [598]:
Visitors: 597
Today: 54602
Total: 107235446
Forums › The Car › 206 Problems › help asap please video of it now up
Go to page Previous  1, 2
PostPosted: Sat May 26, 2012 2:47 am Up
20619d wrote:
i cant seem get it to undo so can pull it back so it tight
They have used threadlock on that nut and it will be seized as well.
Use WD40 overnight on the whole assembly.
Again, do not over-tense the spring.
You are definately not meant to hook to a pipe, there is a small side-mounted
bolt on the arm with a 'collar' on it which it hooks onto.
As Mr.BSI says you must check it in a garage sometime soon as it's a safety issue.
This is not a regular adjustment 'to your preference' so to speak.
However, it is possible to get it pretty damn spot-on if you try hard enough.
Page 2 of 2
