Latest: cogeim7
Overall: 17185
Online Now [599]:
Visitors: 599
Today: 1321
Total: 147739717
Forums › The Car › 206 Problems › Sticky / Notchy Clutch Pedal
skov
PostPosted: Mon May 28, 2012 2:16 am Up
Hi All,
Just bought a 2004 206 gti last week (137 bhp version).
Had to drive it in start-stop traffic for the first time today, and noticed the clutch pedal is very sticky/notchy.
It's particularly bad around the biting point, which makes it difficult to drive smoothly!
Any ideas?
Thanks!
Schumi
PostPosted: Mon May 28, 2012 2:21 am Up
I dont know your car have hydraulic clutch or cable operated clutch but if cable operated problem could be cable's itself.
2005 206 RC RED
PostPosted: Mon May 28, 2012 3:58 am Up
Gti's are hydrolic.
skov
PostPosted: Mon May 28, 2012 4:24 am Up
Just had a look - it's hydraulic.
When I push the pedal in and out there's a definite creaking noise too.
Can't tell if it's coming from the pedal or the gearbox end though.
Walton450
PostPosted: Mon May 28, 2012 12:15 pm Up
is the fluid level ok? if so could try changing the fluild or if if still does not work you may have to change out the master cylined as the internals can wear and make the pressure drop as you depress the pedal. (£10 for the cylined off a breaker)
I\'m Steve got a 2003 verve.
Schumi
PostPosted: Tue May 29, 2012 1:03 am Up
Gti's are hydrolic.
Yep RHD ones. LHD GTI's are cable.
2005 206 RC RED
PostPosted: Tue May 29, 2012 1:59 am Up
Highly likely it's a seized hydraulic cylinder piston.
skov
PostPosted: Tue May 29, 2012 6:24 am Up
Is there any way of checking whether it's a dodgy piston/cylinder without taking it apart?
And is it more likely to be the master or slave cylinder?
Walton450
PostPosted: Tue May 29, 2012 9:15 am Up
More likely the master attached to the pedal. That would be the cheapest place to start. I think you have to remove the box to change the slave. If you have a Haynes manual it tells you how to remove and re fit. It says it's do able for a DIY machine.
PostPosted: Tue May 29, 2012 9:32 am Up
Nope the slaves outside the box pretty simple to change 2 torx bolts and the hydrolic fluid pipe. Think i paid £23 for one from peugeot a few mo ths ago.
pug206lx
PostPosted: Tue May 29, 2012 2:30 pm Up
I took the box off my sisters 206 1.4 that had a similar problem, it was the release bearing not sliding properly on the gearbox shaft and sticking.
PostPosted: Tue May 29, 2012 3:29 pm Up
Had exactly same symptoms, had my clutch and slave cylinder changed today.
skov
PostPosted: Tue May 29, 2012 4:21 pm Up
Bu99er - I was hoping it wasn't going to be the clutch bearing!
How hard is it to get the box off?
On my last car you had to drop the whole front subframe...
I suppose I'd better buy the Haynes manual!
Sig
PostPosted: Tue May 29, 2012 4:26 pm Up
Not a difficult job, can be done without touching the subframe with enough patience.
