Online Now [317]:
Visitors: 316
Today: 78990
Total: 142589404
Forums › The Car › 206 Problems › Impact sensor
Impact sensor
Bill_G
PostPosted: Tue May 29, 2012 7:04 am Up
another spoon feeding session please,
the short of it is the drivers seat air bag has been deployed which i have now replaced but obviously the dash light is still on. after doing some reading i believe there to be 2 sensors, one under the steering column which deals with driver and passenger air bags (?) and the one for the curtain air bags are in the sills.
is there a sensor on each side and where abouts is this secondary sensor located. car is a 2002 206 gti
please help as new MOT rules wont pass a car withe dash llights illuminated
unique doesn't always mean useful
Ash
PostPosted: Tue May 29, 2012 7:21 am Up
You need to get a new Airbag ECU if I remember correctly.
PostPosted: Tue May 29, 2012 8:10 am Up
Thanks to VOSA c**k up over the new MOT rules you can just cover the airbag warning light with black tape & it will be pass & advise Rolling Eyes
On a multiplexed 206 the 1 & only arbag ecu is under the front ashtray controls ALL the airbags & seatbelt pretensioners.
There is a satellite sensor on each sill for the side & curtain airbags that feeds impact information to the main airbag ecu which will decide if an airbag / airbags / pretensioners need to be fired.
Bill_G
PostPosted: Tue May 29, 2012 8:30 am Up
yeah at the moment i dont think the rule has been implemented accoding to the guy who does my MOT's
can u get to the sensor by just taking the shtray out of does the whole tunnel pastic stuff have to come out?
PostPosted: Tue May 29, 2012 8:38 am Up
If you remove the front ashtray you should be able to see the airbag ecu ( might need to move the carpet flap )
Its best got at after removing the center console, airbag ecu is sometimes hidden under a flap of carpet.
If you have small hands & a 1/4 drive socket set you MAY be able to get at the 3 nuts & free the ecu but its easy enough just to remove the center console & not have to struggle.
3 x 10mm nuts secure the airbag ecu to the floor.
ID numbers are on the unit sticker OR get the crash data erased from the memory Whistle...
Bill_G
PostPosted: Tue May 29, 2012 8:48 am Up
i do have very womanly hands lol. yeah im gonna get teh crash data erased unles i can find a cheap sensor, but the risk is allways that could have something logged on it too.
Mr BSI u have been most helpful, cheers pal
PostPosted: Tue May 29, 2012 8:54 am Up
If you go replacement airbag ecu route you need an unfired one from a multiplexed 206 with side airbags.
If its also has curtain airbags the airbag ecu would need to be reconfigured.
A multiplexed 206 with just front airbags ( loads of these type about ) uses a different airbag ecu & one of those is no good for your car.
Easy option = get the crash data sorted on your own airbag ecu.
Squeaker
PostPosted: Tue May 29, 2012 3:39 pm Up
Or you could buy my Ecu Smile
PostPosted: Tue May 29, 2012 4:10 pm Up
If it came from a 206 with curtain airbags it wouldnt really be cost effective.
Just as easy to get the crash data from his own ecu.
QuArTz
PostPosted: Wed May 30, 2012 8:41 am Up
Trade Rating: +16
This might help you>> www.206info.co.uk/Foru...46354.html Wink
Squeaker
PostPosted: Wed May 30, 2012 11:35 am Up
It has got curtain airbags, its been on Ebay a while.
PostPosted: Wed May 30, 2012 11:39 am Up
Then it would need reconfiguration to fit the 206 Bill_G has & that means either Peugeot Planet or paying someone else to do it Wink
