Online Now [189]:
Visitors: 188
Today: 25443
Total: 142931560
Forums › The Car › 206 Problems › Sticky / Notchy Clutch Pedal
Go to page Previous  1, 2
skov
PostPosted: Wed May 30, 2012 11:27 pm Up
I got someone to push the pedal while I had a listen.
The noise is definitely coming from the engine bay, and I'm 99% sure it's coming from inside the bellhousing.
Picked up a Haynes manual yesterday - it makes changing the clutch sound easy Very Happy
Going to pick up a clutch kit today and have a bash at it over the long weekend.
I'll let you know how I get on!
PostPosted: Thu May 31, 2012 6:12 am Up
If you take the airfilter housing out, you'll see the slave cylinder on front of the gearbox. Listen for a creaking sound when the clutch is pressed. Mine was changed as well as the clutch, my mechanic then told me my clutch was fine, and the cylinder was leaking. My symptoms were a sticky clutch, high bite point and juddering when pulling off. Might save yourself a lot of work, and save £150!
PostPosted: Thu May 31, 2012 6:32 am Up
+1
PostPosted: Thu May 31, 2012 11:58 am Up
Generally, if the clutch isn't slipping, it's not at fault
skov
PostPosted: Thu May 31, 2012 1:20 pm Up
I'll have a look at the slave first then.
With any luck it'll just be that and I can get a refund on the clutch kit!
PostPosted: Thu May 31, 2012 2:24 pm Up
Try bleeding it and go from there
skov
PostPosted: Mon Jun 04, 2012 9:35 am Up
Stuck a new slave cylinder on today, then spent all chuffing afternoon trying to bleed it.
The damn thing's still full of air and won't pump any fluid!
skov
PostPosted: Mon Jun 04, 2012 2:33 pm Up
Turn's out dedication's what you need! (and a pair of safety glasses next time after getting brake fluid in my left eye...)
Don't you just love it when these half hour jobs turn into 6 hours of swearing.
Only had a very quick test drive, it feels smoother than it did, but still a bit graunchy right at the end of the pedal travel (pedal fully in).
Previously it was worse when warm, so I'll have to wait until my commute on Wednesday to see how much (if any) improvement I really have.
UPDATE: Drove 50 miles or so today, and it feels MUCH better Very Happy
There's still a tiny bit of roughness in the pedal when fully in, but it's nowhere near the biting point, so not causing me any trouble or p!ssing me off!
PostPosted: Thu Jun 07, 2012 2:32 pm Up
Good too hear!
Page 2 of 2
