Latest: Beduff1977
Overall: 17134
Online Now [118]:
Visitors: 117
Today: 100119
Total: 107090057
Forums › The Car › 206 Problems › Help my gasket seal failed and oil is everywhere ,!!!
Go to page Previous  1, 2
PostPosted: Wed May 30, 2012 12:54 am Up
Just use turps on a brush to scrub it off. It's cheap and most people have some. Wash it off with soapy water afterwards.
nemesislee
PostPosted: Wed May 30, 2012 1:13 pm Up
well ive totally ballsed it up torqued the bolt just one click too many and bang of came the bolt head Sad
does anyone know how much it will be to have a garage sort it out?
im such a numpty lol
peugeot 206 silver 1.4ltr lx
PostPosted: Wed May 30, 2012 4:04 pm Up
Do it yourself, just get a stud extraction kit.
PostPosted: Fri Jun 01, 2012 12:22 pm Up
Once the rocker cover is off you may be able to grip the remaining part with "mole" grips and undo it yourself. If the head of the bolt snapped undoing the other bolt should let you take the cover off.
Page 2 of 2
