Latest: sparrowdclxvi
Overall: 17139
Online Now [125]:
Visitors: 123
Members: 1
Today: 20737
Total: 113060257
Forums › The Car › 206 Problems › Brake Servo Change?
Brake Servo Change?
Nuve
PostPosted: Mon Jun 04, 2012 10:08 am Up
Well pretty sure the servo is kaput but was just wondering on a couple details first .. firstly .. the pipe from the minifold to the servo .. should air only flow one way thru it ? as mines flowing from both .. also does anybody have a how to guide for removing a servo? (without having to drain my brake system) ?
its a 2005 206 1.4 triptronic
thanks alot for any help
a
iainlovatt
PostPosted: Mon Jun 04, 2012 10:27 am Up
When i replaced mine the brake fluid went everywhere, luckily it was in a scrapyard from one i was removing!! U will also need to remove the whole glove box to be able to get to the bolts that hold the servo in place!
ps what makes you say the servo is faulty??
(My Garage)
Nuve
PostPosted: Mon Jun 04, 2012 10:29 am Up
hissing coming from the passenger footwell when i use the brakes .. yea seen the 4 bolts behind the glove box .. just trying to work out a way of changing it without loosing a ton of fluid lol
a
cartoonhead
PostPosted: Mon Jun 04, 2012 10:37 am Up
undo master cylinder's 2 (im sure it's 13mm) nuts and it should move out the way of the servo and to undo the servo its all behind the glove box Wink
Nuve
PostPosted: Mon Jun 04, 2012 11:05 am Up
loving the sound of that mate .. sounds pretty simple .. any guides kicking about on the glovebox? imagine it being fiddly by the looks of it
a
iainlovatt
PostPosted: Mon Jun 04, 2012 11:45 am Up
Remove the door of the glovebox, then just undo the bolts around its should slide away 5 min job,
(My Garage)
Nuve
PostPosted: Mon Jun 04, 2012 12:03 pm Up
cool will give it a bash .. thanks alot cartoonhead .. if your way works i owe u a couple pints ! cheers
a
PostPosted: Mon Jun 04, 2012 2:22 pm Up
you can't change the servo without draining the oil in the system,but to make the mess less,suck in all the oil in the bottle,and then take out the pipes that goes from the servo or master cylinder,to the ABS pump,this will be the less messy,BUT,you have to drain the 4 wheels from the air,before you drive the car anywhere.
cartoonhead
PostPosted: Mon Jun 04, 2012 4:25 pm Up
had to do mine not long ago after i got sick of listening to the fisssss every time i touched the brake peddal Wink
Nuve
PostPosted: Tue Jun 05, 2012 2:17 am Up
and did you have to drain the system at all?
a
cartoonhead
PostPosted: Tue Jun 05, 2012 11:28 am Up
nope Smile
iainlovatt
PostPosted: Sun Jun 10, 2012 6:12 am Up
I paid a guy to install the second hand part i got for £35 quid, couldn't be bothered with the hassle of messing it up, especially with it being with the breaks lol!
(My Garage)
