Online Now [595]:
Visitors: 594
Today: 118689
Total: 145081114
Project sleeper
Go to page Previous  1, 2, 3 ... 13, 14, 15 ... 85, 86, 87  Next
tRiCk
PostPosted: Tue Mar 16, 2010 6:47 pm Up
Been watching this for a while I dunno what to say other than its amazing. But a real shame that it wont be at a car show so i can have a real good look.
PostPosted: Wed Mar 17, 2010 2:39 am Up
macj wrote:
Are you getting a torque steer on acceleration from standstill and trouble stopping it wanting to light up one wheel
It will light them up if i try but after that it doesn't seem to pull a great deal harder than it did before. Yes it revs higher but there's no step in the torque and no clear power band. Basically it feels a bit flat at times.
Brian wrote:
That looks absolutely stunning Tedward! As mentioned, that head is crying out for a cover...Ecosse do a nice carbon fibre one which would go with your airbox
They offered me one and I didn't want it.
Steve206 wrote:
Just noticed your strutbrace is off the car as well?
It gets in the way of work and doesn't do anything anyway.
JDave wrote:
The bay is looking cracking. Have you taken the engine cover off? Is that not risky?
It doesn't do anything and it's been off for the last 3 years...
Jamie wrote:
Were there any issues with the radiator?
There is about 5mm between the radiator and airbox. I've seen Longmans cars with the radiator housing moved forwards to provide clearance. With the uprated engine mounts the engine doesn't move too much so it's not an issue. I'd be a bit concerned if the mounts weren't fitted though.
PostPosted: Wed Mar 17, 2010 2:42 am Up
I'm confused, so are you happy with it or not?
Does look good, but the main reason for it is the power, 'so if its feeling flat'...
PostPosted: Wed Mar 17, 2010 2:49 am Up
I'll post up the rolling road print later for you guys to analyse...
jimmyfloydreturns
PostPosted: Wed Mar 17, 2010 3:20 am Up
Looks amazing Edward! I love how you have kept the whole car standard, same as what I would do Thumb Up Man I miss my GTi Sad
So.... whats all this about disappointing power delivery?
Used to have Moonstone 206 GTi (miss her!)
VW Polo Bluemotion - SWMBO's
Mark 1 MX5 - Soon to be sold
Honda S2000 GT
Click for my projects thread
Click for alloy refurb how to guide
vanman_foci
PostPosted: Wed Mar 17, 2010 4:33 am Up
I must say I have been watching this from the start and I love how it looks standard now Very Happy
Bit gutted for you as you don't seem happy with it! Hope you sort it out soon.
Seb
PostPosted: Wed Mar 17, 2010 4:59 am Up
Staff - Seb
I'd like to see the graph, whether the figures are accurate or not means nothing, I just want to see the shape, see if it looks like there's anything up with it.
PostPosted: Wed Mar 17, 2010 1:08 pm Up
One rolling road print out...
Geoff
PostPosted: Wed Mar 17, 2010 1:27 pm Up
Thats a bit of kink at 4500rpm!
I've just had a look at the longmans spec:
Max power: 190bhp @ 6750rpm
Max torque: 170lb ft @ 5500rpm
From the impression from reading the above you don't seem totally happy. I would be interested in what the others say when they see the above graph. Very Happy
Mattie-RS
PostPosted: Wed Mar 17, 2010 1:36 pm Up
is there a graph for air/fuel ratio??
macj
PostPosted: Wed Mar 17, 2010 1:41 pm Up
Power curve is the wrong way and you should see at least another 10ft/lb of torque with those cams.
I need more time to study the graph but I think you have a torque curve issue. My only thoughts are that they have mapped it with 14.7lambda but have not fuelled it enough at the top of the rev range. The MOT test would not reach that sort of RPM. They also set the rev limiter too high in the RR session.
Give me a PM if you want to discuss it further
PostPosted: Wed Mar 17, 2010 1:43 pm Up
I'm quite underwhelmed by it to be honest. There is no mid range as such either, it pulls but doesn't feel quick. Looking at the before and after charts it appears to have less torque at 4500rpm than before.
It is fast higher up the rev range but it doesn't exactly blow your socks off.
Nope.
PostPosted: Wed Mar 17, 2010 1:45 pm Up
Which they would have to do in order to keep the cat working long term? I believe such cams dictate the need for richer mixtures but those and cats don't go together.
Seb
PostPosted: Wed Mar 17, 2010 2:05 pm Up
Staff - Seb
It's a shame you're not so pleased with it Edward. After the time and effort that has gone into it Sad
SAB206
PostPosted: Wed Mar 17, 2010 2:53 pm Up
Work that's done looks very neatly done, I like the OEM subtle look of it all.
It's a shame you're a bit dissapointed with it, I once went out In Bonsons car, and that felt MUCH different to the power delivery of the 180. It did knock me and throw me back in the seat, even mid-range it packed quite a punch.
I'm with you on the RR results too, all of them are a bit peculiar, but your torque is showing VERY similar to that of a 180 (mines 154ibft 0, should it not 'theoretically' be somewhat higher?
www.sab-graphics.com
I AM SYDLEXIC!
Page 14 of 87
