Latest: jackrox1992
Overall: 17186
Online Now [653]:
Visitors: 652
Today: 56383
Total: 147785321
Forums › The Car › 206 Problems › key transponder not working
simon_lenard
PostPosted: Tue Jun 05, 2012 10:07 am Up
I have a problem with my central locking firstly didnt work at all so i disconnected all cables from my bsi taped it reconnected all cables and then central locking started to work (bsi is temperamental it will work for few days and then its getting loose again at least i presume so and it stops working again) but not with transponder just with key, i tried to pair it few times but i failed. So i was advised to get my self a new ecu,bsi and transponder but can i just plug another set? any advices?
pug 206 hdi
PostPosted: Tue Jun 05, 2012 10:13 am Up
They all need to match.
simon_lenard
PostPosted: Tue Jun 05, 2012 10:17 am Up
hi yes i was told that i should buy the whole set but when i will have it is it just case of swapping it or i am being just naive? also is there any bsi repair service?
pug 206 hdi
PostPosted: Tue Jun 05, 2012 10:42 am Up
Yep basically just swap it.
You can get the BSI repaired, but it's generally cheaper to replace.
