Posted: Wed Jun 06, 2012 2:53 pm |
Nope!
| \"dad, can you have a look at my car\" | |
Posted: Wed Jun 06, 2012 3:07 pm |
Lee wrote: |
£60 for a CAT? aye f*** off, it'll last about as long as me if I was in bed with Jessica Alba and Tulisa! |
So it will break before you've even stripped the car.
P.S. Lee. Tulisa. Really? Haven't you seen the video?
Posted: Wed Jun 06, 2012 3:26 pm |
Ash wrote: |
Lee wrote: |
P.S. Lee. Tulisa. Really? Haven't you seen the video?  |
I've seen it ....I'd rather watch the news!
Anyway, any thoughts on the coil pack?
Posted: Wed Jun 06, 2012 3:57 pm |
Ash wrote: |
Lee wrote: |
Yeah I've seen it. But doesn't change the fact that I think she's amazing lol
Posted: Wed Jun 06, 2012 4:02 pm |
ideally you need to get the code read otherwise you will have to isolate the problem stepwise....
randomly replacing parts isn't the best practise.
cat glowing red/ overheating indicate high work load on the cat.
could be misfire or running rich.
that means coilpack, injectors, spark plug, O2 sensor or even MAP sensor could play a roll.....
even if the timing belt jump a tooth would cause misfiring.....
you really need to get the code read to narrow down the choices...
Posted: Wed Jun 06, 2012 4:05 pm |
Posted: Wed Jun 06, 2012 4:10 pm |
Posted: Wed Jun 06, 2012 7:05 pm |
I had this on my 1.4 a few months back, no power, eml flashing, cat was glowing. stank of fuel, turned out to be the coil pack had packed up.
Cat glowing shows unburnt fuel detonating in the cat causing it to get even hotter than usual.
Posted: Thu Jun 07, 2012 9:51 am |
Thanks Lee, that's what I'm thinking. Did you get any fault codes? There's nothing showing on the display say any fault code that's why I'm reluctant to get it read. I do appreciate the input from sea book tho.
Posted: Thu Jun 07, 2012 10:02 am |
Seabook wrote: |
Works for people / garages that havent got a clue
As its a TU lump then the coolant temp sensor which is a know weakness would be the first place I would look.
Posted: Thu Jun 07, 2012 3:17 pm |
MrBSI wrote: |
Seabook wrote: |
As its a TU lump then the coolant temp sensor which is a know weakness would be the first place I would look. |
should be able to spot that if you get the live data reading?
Posted: Thu Jun 07, 2012 3:36 pm |
Posted: Sat Jun 09, 2012 9:45 am |
LeeThr wrote: |
Cat glowing shows unburnt fuel detonating in the cat causing it to get even hotter than usual. |
Changed the coil pack and whoo hoo, success!
Thanks everyone.
Posted: Wed Jun 13, 2012 2:45 pm |
dmcwe wrote: |
LeeThr wrote: |
Thanks everyone. |
glad you sorted it out
