Latest: tebas93089
Overall: 17179
Online Now [92]:
Visitors: 91
Today: 76
Total: 138261426
Forums › The Car › 206 Problems › Failed emissions 5 times!!!!!!
x_lyns_x
PostPosted: Thu Jun 07, 2012 11:16 am Up
Anyone got any ideas im all out now.... My peugeot 206 1.4 8v has failed its mot on emissions, i then went ahead with a full service...failed again.....new o2 sensor...failed again...new map sensor...failed again...new cat failed again. Its only failing on CO the first time it read 0.65 and after all the new parts its down to 0.5 and needs to be no more than 0.3 for a pass. Oh its also been hooked up-to a reader and it was showing no fault codes???? Anyone.....anything???
this 206 is driving me nuts but shes plenty of life left yet..........
Sprotty
PostPosted: Thu Jun 07, 2012 11:28 am Up
Give it a good thrash before testing! Get the cat nice and hot as this is when they work best.
Life at full throttle...
PostPosted: Thu Jun 07, 2012 11:55 am Up
Fill up with Shell V Power, give it a good run and then check the emissions. Might need a couple of tanks to give the engine a good clean but worth the cost to get the emissions down.
PostPosted: Thu Jun 07, 2012 12:11 pm Up
Read the live data, just throwing replacement parts at a car in an attempt to fix it isnt the way to do things Wink
PostPosted: Thu Jun 07, 2012 12:46 pm Up
Slip the MOT'er £20 to not test the emissions.
marc206
PostPosted: Thu Jun 07, 2012 12:52 pm Up
give it a good thrash before testing or this:
Wink
Ash
PostPosted: Thu Jun 07, 2012 12:57 pm Up
Wink
No No No, test the emissions. Just stick the pipe up a shiney new Beemer Smile
PostPosted: Thu Jun 07, 2012 1:06 pm Up
Its just as easy to fix the fault with the car Wink
x_lyns_x
PostPosted: Thu Jun 07, 2012 1:20 pm Up
ive been checking as its just high CO readings to me indicates its been starved of air or overfueled , i forgot to mention it passes on natural idle, however i have just took the air box off to check if it is blocked in any way and found that the pipe/box from the front arch to the airbox is filled with water which in theory could allow it to pass on idle but fail on "fast idle" as it only allows enough air for burning efficient on tick over, anyway im charging my drill now and going to bang a couple of drain holes into it and see how it goes on emissions number 6
Robert594
PostPosted: Thu Jun 07, 2012 1:26 pm Up
I had a 206 that failed on emissions several times, replaced cat, replaced sensor etc... Turned out it was the wiring loom from the engine going to one of the sensors.. But i didnt have the money to get the loom sorted..So i ended up getting rid of the car Sad
PostPosted: Thu Jun 07, 2012 1:34 pm Up
Ash wrote:
Wink
That's what they normally do, as they still have to run a test, but just put a new car on the ramps.
Emissions test is a load of bollox anyway.
x_lyns_x
PostPosted: Thu Jun 07, 2012 3:19 pm Up
just took it for a test drive after removing the water from the airbox feed pipe (comes from nsf arch to under airbox) car goes like mad now..... most power its had since ive owned it, defo more efficient fuel burning now lets see on the emissions test
PostPosted: Thu Jun 07, 2012 3:33 pm Up
it is very common to have water in the airbox down pipe....
even more common to suck water up and mess up the MAP sensor too....esp. under heavy rain
PostPosted: Fri Jun 08, 2012 2:18 am Up
Good on you.
That box is the resonator by the way which is well known to get damaged allowing water to get-in.
It might be worth examining it and replacing as it's bound to have a problem by the sound of it.
spike_202
PostPosted: Fri Jun 08, 2012 3:12 am Up
Try sOme petrol additive such as red x then take it for a spirited drive.
**spike's project**
TEAM:+200bhp
