Latest: Worthy967
Overall: 17143
Online Now [626]:
Visitors: 625
Today: 82189
Total: 114982486
Forums › The Car › 206 Talk › soundproof bonnet?
soundproof bonnet?
Adam2061994
PostPosted: Thu Jun 07, 2012 4:16 pm Up
any body sound proofed there bonnet so they dont hear any ticking or anything like that at all? and if they have what do they use and was it hard?
206 1.6 owner
PostPosted: Thu Jun 07, 2012 4:18 pm Up
you suppose to have the insulation material on the bonnet.....
plus you can stuff up the door seal; that really cut out quite a lot of noise from outside....
Adam2061994
PostPosted: Thu Jun 07, 2012 4:25 pm Up
well when i bought mine it didnt have it so im wondering if i could redo it, and i just want the engine bay a little quieter that is all ?
206 1.6 owner
PostPosted: Thu Jun 07, 2012 4:29 pm Up
i presume you can buy that from dealer?
Still_Rolling
PostPosted: Thu Jun 07, 2012 4:34 pm Up
If you put one in, make sure it's secure right in the middle. Mine wasnt, and started melting on the engine. The amount of smoke it created, I thought the engine was on fire! Needless to say I took it off as soon as I got home.
Always Rolling...
spike_202
PostPosted: Thu Jun 07, 2012 5:00 pm Up
Im taking mine off as it's saggy in the middle and rubs on my engine cover.
**spike's project**
TEAM:+200bhp
MrZiggerz
PostPosted: Thu Jun 07, 2012 5:30 pm Up
Explain this stuff up the door seal, im interested Smile
Adam2061994
PostPosted: Thu Jun 07, 2012 11:53 pm Up
how much do you think it would cost from the dealer? thanks Smile
206 1.6 owner
PostPosted: Fri Jun 08, 2012 2:49 am Up
7979F0 Sound Proofing £71.08 plus £1.62 for the fixings.
I bought one last year. Looked around the scrappies first but they were all battered and sagging so decided new was the best way.
PostPosted: Fri Jun 08, 2012 12:22 pm Up
Does it cause the engine-bay to run at higher temp?
Does it make the car quieter by much? (in the cabin ofcourse)
PostPosted: Fri Jun 08, 2012 12:53 pm Up
I've not noticed the engine run any hotter and doesn't seem any quieter. It did reach running temperature quicker in winter though.
devildriverxii
PostPosted: Fri Jun 08, 2012 3:17 pm Up
I drive a 2.0 HDI, it sounds like a ruddy minibus =(
2002 1.6 5dr Black Edition.
PostPosted: Fri Jun 08, 2012 3:32 pm Up
That's not good news for our 40 C in the shade during summer.
Probably why I've never seen a 206 with the bonnet shield over here,
and I've had a look at a fair few in all these years.
Then again I'm convinced one should avoid running the car at those ambient temps unless really necessary.
Ash
PostPosted: Sat Jun 09, 2012 4:15 am Up
I fitted one. Bought it from here for a tenner. No real noise difference but it did warm up quicker and retain heat for longer.
If you wanna deaden it, put some proper sound deadening on the inside of the bonnet and firewall. However, you will need to check the temperature rating and it will make everything heavy.
