Online Now [576]:
Visitors: 576
Today: 101205
Total: 105678126
Forums › The Car › 206 Problems › screeching brakes and very hot disc on front O/S wheel
sayn117
PostPosted: Sun Jun 17, 2012 11:06 am Up
My 206 has started to make a loud screeching noise after I've driven for a while (the sound seems to stop when I press the brake lightly or turn the wheel slightly).
It sounds like its coming from the front O/S wheel and that wheel gets a lot hotter than the other side (I sprayed a little bit of water on it and it instantly turned to steam so its getting very hot).
Any ideas what might be wrong? could it be a seizing caliper and is it an easy fix?
206 LX
sayn117
its a 2001 1.4 LX, with no ABS
206 LX
Walton450
PostPosted: Sun Jun 17, 2012 11:18 am Up
If its the capiler. Would be easier to just fit a replacement. either new if your felling rich or just one off a breaker. It could just be a warped disc. How old are the discs and pads?
I\'m Steve got a 2003 verve.
sayn117
PostPosted: Sun Jun 17, 2012 11:26 am Up
Pads were changed a few months ago. No idea about the discs I've had it for about 2.5 years. Would there be any way to test if its a warped disc?
206 LX
Walton450
PostPosted: Sun Jun 17, 2012 11:36 am Up
Reley should change the disc when you change the pads. It just jack the wheel up. The very un technical way is just spin the wheel and lission if it grips at any point and if it's the same point on the wheel every spin. Discs are only £40 ish
PostPosted: Mon Jun 18, 2012 4:44 pm Up
Changing discs with every set of pads is over kill. Most discs will last at least 3x pad changes and more. If this was a very high performance car I might agree but even then I would measure thickness and look at surface condition but this it is a 1.4 206 a low performance car. I am not stating the discs don't need changing but know why you are changing them not just doing it by routine though they are cheap at £20 per pair or less.
Also very few discs warp but they do get pad imprints either problem gives the symptom of brake judder and the OP hasn't make any comment about that. For a slightly technical reference to warped discs and brake problem myth busting read here;-
www.stoptech.com/techn...ther-myths
FWIW my suggestion is that when the new pads were fitted the pistons were pushed back into the calliper without first cleaning the piston. Having done that a previously exposed and dirty or even rusty part of the piston has now caused the piston to be a tight fit in the calliper and the partially seized piston is making the brake drag. The solution is either remove the piston and clean it using brake cleaner, fit a calliper repair kit (new piston, new pressure and dust seal) or replacement calliper. NOTE: if the dust seal on the piston is split it is likely that the piston will be rusty and beyond repair.
You will need to bleed the brakes after the repair.
PostPosted: Mon Jun 18, 2012 4:56 pm Up
What He Said I agree! I agree!
rarely see such a quality reply on info these day
