Online Now [254]:
Visitors: 253
Today: 53883
Total: 138675514
Forums › The Car › 206 Problems › Airbag ecu
Airbag ecu
Banzai_Baby
PostPosted: Tue Jun 19, 2012 9:52 am Up
Last weekend i had a bit of a dukes of hazzard event off a hump back bridge. I have replaced the 2 front seatbelts but the airbag light won't go out. I took it to the garage today to get the airbag ecu reset, but it wouldn't wipe the code from the memory. Has anyone got any ideas how or what to do to to get the light off. Its my dads car i i'd prefer if he didn't find out. Its a 2006 206 SW verve
Banzai
PostPosted: Tue Jun 19, 2012 10:06 am Up
You need special equipment to erase the crash data, most garages wont be able to do it.
PostPosted: Tue Jun 19, 2012 12:47 pm Up
Data is sorted in 95080
Banzai_Baby
PostPosted: Tue Jun 19, 2012 1:48 pm Up
The guy in the garage tried 2 different machines and both read the code but failed to delete it. Looks like need to go to the dealer. He mentioned something about a crash sensor. Any ideas where that is ? Would it e possable to disconnect the airbag ecu and still be able to drive or would the light still be on anyway ? Sounds expensive going to peugeot
Banzai
PostPosted: Tue Jun 19, 2012 2:07 pm Up
Peugeot won't do it, they don't do eeprom work! They'll just replace the ECU
Cheapest resolution would be to buy a second hand ECU with no crash data sorted!
PostPosted: Tue Jun 19, 2012 6:57 pm Up
Banzai_Baby is going to learn an expensive lesson. Less Banzai with dad's car and more treating it like a baby needed.
Banzai_Baby
PostPosted: Wed Jun 20, 2012 9:47 am Up
I've been driving for the last 17years and have had no incidents before. This will teach me to try run a light
Banzai
Banzai_Baby
PostPosted: Wed Jun 20, 2012 9:50 am Up
with a second hand ecu, it still needs to be the exact same part number or will a similar one be ok ?
Banzai
Banzai_Baby
PostPosted: Sat Jun 23, 2012 8:33 am Up
peugeot finally fitted the new airbag ecu, expensive at £310 including fitting
Banzai
