Posted: Sun Jun 17, 2012 1:05 pm |
Hi,
As per topic, took my daughter out in car yesterday put her in back behind passenger seat and the footwell behind there was flooded!!!. No blockages in door or leaks from above and the only thing I could find was slight water when I lifted the back seat up. There appears to be like a black seal there. Is this where it was coming from??? Need to add car was parked on a driveaway at no angle so god knows how this got in the car!!
Your thoughts appreciated as always!!!
Posted: Sun Jun 17, 2012 1:40 pm |
Heater Matrix
Posted: Sun Jun 17, 2012 1:43 pm |
is your boot floor wet? is it 3dr or 5dr? and is it wet under the passenger front carpet?
| 2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd | |
Posted: Sun Jun 17, 2012 2:07 pm |
sell sell sell
Posted: Sun Jun 17, 2012 2:27 pm |
what the smell of this water like?color?
Posted: Sun Jun 17, 2012 2:54 pm |
rear boot seal! water for me has come in that way before!!
Posted: Sun Jun 17, 2012 4:30 pm |
I have had wet rear sets from a rear window seal before.
Posted: Mon Jun 18, 2012 1:20 am |
Thanks for your replies Guys!!!
It is a 5 door car, and only the rear passenger carpet was wet, rest of car was completely dry.
Surely cannot be heater matrix as that is underneath the dash and front would be wet.
Boot is dry but has been slightly wet in the past. I think will silicone up the seals underneath the rear seat and see what happens especially since it is still peeing down with rain at the moment
Posted: Mon Jun 18, 2012 1:27 am |
Probably coming in through the boot seal and trickling into the car (the footwells being the lowest point in the car). Water can be a funny thing, you only can find it in the one place it ends up and you have to trace it back to the source.
Open the boot and see if the ducts have any evidence of water
Posted: Mon Jun 18, 2012 1:33 am |
Cheers Deadeyepaul will do
Posted: Wed Jun 20, 2012 2:02 pm |
will you have to check the rear passenger door,pour some water on the window,while you are checking the door cards lower part,if you get wet hands,that means that you need to get fixed,will tell you how if it turns to be that is the cause.
Posted: Wed Jun 20, 2012 3:28 pm |
Happened to me and it came front the front footwell under the carpet and settled in the back it may not seem wet in the front as it didn't on mine
Posted: Thu Jun 21, 2012 1:47 am |
Hi,
Will check it out as it is peeing down heavy again my way!!!
