Online Now [38]:
Visitors: 37
Today: 18734
Total: 117205329
Forums › The Car › 206 Talk › Wiring Help
Wiring Help
Jack123
PostPosted: Thu Jun 21, 2012 7:03 am Up
basically, Ia m trying to wire a switch for some footwell lights, using the Alarm switch, but, from what I have found, wired up, It is only a momentary switch, not a toggle one, is there anyway I can adapt or change it so, instead of it only being off when I hold it in, It will be off when I press it in and let go, then on when I do the same again.
The inside of the switch looks like this;
- o o
0 0 0
The - means a connector, the o basically means where there is a hole for a conector.
I was connecting up to the top left and top right, works both ways around, just not how I want it to work.
Any ideas? I really want to use the Alarm switch, so people can't tell its there really, and it looks like I have an alarm Laughing
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
PostPosted: Thu Jun 21, 2012 7:07 am Up
Should have got the rear electric window child isolator switch.
Jack123
PostPosted: Thu Jun 21, 2012 7:11 am Up
Does that fit in the same place? Or is that elsewhere? I can nip down the scrappy at the weekend to look for one.
Wanted List;
Crystal Headlights.
PostPosted: Thu Jun 21, 2012 7:38 am Up
Just wire it up to a new switch.
