Online Now [148]:
Visitors: 147
Today: 25645
Total: 143334620
Forums › The Car › 206 Problems › 206 8v 1.4 02 plate misfire
b19jmc
PostPosted: Thu Jun 21, 2012 3:28 pm Up
hi i have an 02 plate 1.4 quiksilver it has mis fire and buzzer sounds and engine warning light flashes on i have small code reader it has p0200 stored injector circuit any ideas what is needed
1.4 quiksilver 8v 02 plate
Camm206
PostPosted: Thu Jun 21, 2012 3:56 pm Up
i had roughly the same problem, i changed the spark plugs - nothing changed still misfired, i changed the coil pack, it sort of got better, eventually ended up changing my injectors problem went straight away hope this helps Smile
1.4 8v, Slowly Getting There
Matt
PostPosted: Thu Jun 21, 2012 4:00 pm Up
Trade Rating: +32
Makes sense to change the cheaper bits first.
Plugs.
Coil pack.
Injectors.
Throttle sensor.
MAF sensor.
pug206lx
PostPosted: Thu Jun 21, 2012 4:41 pm Up
probably injector nearest ecu.
