Latest: jackrox1992
Overall: 17186
Online Now [614]:
Visitors: 613
Today: 165023
Total: 148311732
Forums › The Car › 206 Problems › 180 clicking noise when let off accelerator
L5_UKS
PostPosted: Mon Jun 25, 2012 6:33 am Up
Right got a little problem with the 180, thought id check on here before I take it to the local Rob Dogs to check whats up with it ha.
Basically when I let of the power I will get this like click sound just once it then go on power let off and it will click again :S
Sort of sounds like the throttle cable is lose? and pinging, Its quite hard to explain. If people dont know what I mean I will try get a video of it.
Thanks in advance
Luke.
PostPosted: Mon Jun 25, 2012 6:40 am Up
180 is fly by wire, there isnt a throttle cable.
L5_UKS
PostPosted: Mon Jun 25, 2012 6:41 am Up
Hmmm not that then ha, The sound seems to be louder if you let of the power quickly aswell :s
PostPosted: Mon Jun 25, 2012 6:44 am Up
Not the VVT solenoid sticking / playing up?
L5_UKS
PostPosted: Mon Jun 25, 2012 6:50 am Up
To be honest I've never cleaned it so might be worth giving it a clean see if it makes a difference.
Big_Rich180
PostPosted: Mon Jun 25, 2012 7:03 am Up
Sure its not the engine mount thats gone?
L5_UKS
PostPosted: Mon Jun 25, 2012 7:12 am Up
Engine mounts were all replaced about 7 months ago so cant be that, It sounds like its actually in the cabin aswell as its like really obvious when you know its there.
L5_UKS
PostPosted: Mon Jun 25, 2012 7:24 am Up
Ps where is the vvt just looking now and can't see it. Or am I just being thick? Ha
JamieM
PostPosted: Mon Jun 25, 2012 7:37 am Up
Back of the engine iirc mate
Aegean Blue 206 GTi180
Big_Rich180
PostPosted: Mon Jun 25, 2012 7:53 am Up
IIRC if your looking at the engine its at the back left.
sri16v
PostPosted: Wed Jun 27, 2012 3:52 pm Up
Top engine mount will be causing the noise, will also do it on idle every so often if you listen out for it.
I replaced my top engine mount and still had the same noise, its the little metal strips on the rubber hitting the metal mount.
My guess would be lower engine mount needs replacing again, they dont seem to last long on the 180's.
2004 GTi 180
