Latest: tbafonso
Overall: 17130
Online Now [53]:
Visitors: 52
Today: 27659
Total: 104296008
Forums › The Car › 206 Problems › Rear axle problems again
Go to page Previous  1, 2
PostPosted: Mon Jun 25, 2012 12:05 pm Up
GTSX wrote:
But you can buy the end pieces for 50 euros each.
I just got one axle end and 2 bearing sets delivered 115 euros including postage.
the axle stud are press on and i doubt any garage in UK would touch it.
(apart from axle rebuild company which they can rebuild it of course)
PostPosted: Mon Jun 25, 2012 12:12 pm Up
If / when I come across this issue I might have a crack at it, got a hydraulic press at work Laughing
PostPosted: Mon Jun 25, 2012 12:23 pm Up
www.gmcmotorsport.co.u...d_608.html
this is what he mean.....
and i seriously have no clue how to press the old one out.
spike_202
PostPosted: Mon Jun 25, 2012 12:46 pm Up
Hmmm I have a spare beam round the back of the garage I'll see if there is any way of doing it... I always thought it was a solid bar going right throuh the tube.
**spike's project**
TEAM:+200bhp
PostPosted: Mon Jun 25, 2012 1:21 pm Up
How would the pins come out though? Bit of heat?
PostPosted: Mon Jun 25, 2012 2:39 pm Up
so as the saxo/106 beam.
but in fact i think all of the above you can replace the stud. Laughing
PostPosted: Fri Jun 29, 2012 3:55 pm Up
another pics
pretty sure the tube are press on
spike_202
PostPosted: Fri Jun 29, 2012 3:59 pm Up
Any sign of removing the stub in any way??
**spike's project**
TEAM:+200bhp
PostPosted: Fri Jun 29, 2012 4:04 pm Up
to me it looks like you can pull out the tube and the cross membrane together (as i also see a little gap between the cross membrane and the main tube)....
but 9 out of 10 you need a good machine...so better ask Mr. BSi Laughing
spike_202
PostPosted: Fri Jun 29, 2012 4:18 pm Up
Hmm this could save a few axles including my spare 180 one if they can be removed, new stubs/bearings then it's practically a new axle.
**spike's project**
TEAM:+200bhp
PostPosted: Fri Jun 29, 2012 4:24 pm Up
that's why axle rebuild company always need you old axle back!
spike_202
PostPosted: Fri Jun 29, 2012 4:40 pm Up
Never realy heard or delt with such company's like that, all I did was got a 2nd hand one and had it fitted as only paid £150 (fitted) so I couldn't say no at the time as mine nakkerd.
**spike's project**
TEAM:+200bhp
PostPosted: Fri Jun 29, 2012 4:42 pm Up
nearly all axle rebuild company sold the rebuild axle as exchange bases; you have to pay a deposit which they will refund it to you once you return you old axle
Page 2 of 2
