Online Now [75]:
Visitors: 74
Today: 68609
Total: 116804710
Forums › The Car › 206 Problems › Bloody exhaust flanges
ssjgoku101
PostPosted: Wed Jun 27, 2012 11:58 am Up
Can any of you give me some advice on how to install the exhaust system on a 206 1.6 16v.
No matter how many times I adjust the clamps and pipes I can't stop small gas leaks between the exhaust flanges!
Its like they were designed to be s**t and not fit properly. I was thinking of sticking some exhaust putty on the curved edge since they don't seem to have gaskets.
Cheers
PostPosted: Wed Jun 27, 2012 12:01 pm Up
You are using exhaust assembly paste when you put it together?
Your not just bolting it together dry?
ssjgoku101
PostPosted: Wed Jun 27, 2012 12:08 pm Up
I've used a bit of exhaust putty, doesn't it do the same thing?
Baz
PostPosted: Wed Jun 27, 2012 2:56 pm Up
Do you recommend this? Is it used from standard?
PostPosted: Wed Jun 27, 2012 3:09 pm Up
you don't suppose to use putty any more.....
unless the exhaust is poorly made...
nellyhaggis
PostPosted: Wed Jun 27, 2012 4:22 pm Up
I had this problem with an exhaust.
They are made so cheaply these days and get bashed around being delivered.
Best thing to do if they are leaking at a joint is use a stronger stainless steel clamp.
They don't cost much odd eBay and you can tighten them alot more.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Thu Jun 28, 2012 1:57 am Up
What He Said
Using assembly paste helps create a gas tight seal on the joints. I occasionally use it where one pipe slides into the other and are held by the U-bolt and flange joints with a gasket, but always use it on flange joints with conical gaskets just to make doubly sure there is no leak as get a slight twist on the gasket and you'll have a leak. The only time it wouldn't be needed is if the faces have been machined so accurately that they create a seal from compression alone. Unfortunately off the shelf exhausts aren't usually made to this accuracy.
