Latest: Beduff1977
Overall: 17134
Online Now [160]:
Visitors: 159
Today: 14392
Total: 107195332
Forums › The Car › 206 Problems › 2.0 hdi d turbo no power
Go to page Previous  1, 2
swaynie
PostPosted: Thu Jun 28, 2012 5:33 pm Up
Is it on this pic?
If your offended by my posts call\r\n0800 I dont care Wink
swaynie
PostPosted: Sat Jun 30, 2012 3:49 pm Up
I've sorted it, it was the MAF
loftust
PostPosted: Mon Jan 07, 2013 3:03 pm Up
hayes_ctfc wrote:
Just found this on your chassis number under turbo diagnostics on service box:
INFO’FLASH
058W00U1 : Version 0 of 29/06/2000
FOR : 206 AND TURBO DIESEL DW10TD
CUSTOMER SYMPTOM : The engine lacks power ; Noise at the air intake, whistling of the turbo
CONDITIONS IN WHICH FAULT APPEARS : On acceleration
1. ORIGIN
Disconnection of the sleeve between the turbo and the rigid intake pipe.
2. AFTER-SALES REPAIR
Replace the sleeve .
Remove the rigid intake pipe .
Degrease the turbo and the intake pipe.
Refit the assembly , aligning it carefully.
Replace the clamp securing the sleeve on the turbo with a spring clip (Part number 0382.H6).
Make out a cri for each case encountered.
3. PRODUCTION SOLUTION
for 206 : Being studied.
406 From build code 847089 : Fitting of new collar with spring reserve .
I have exactly the same problem...whereabouts should I be looking in the engine bay for the Turbo sleeve?
I'll check the MAF too.
Page 2 of 2
