Latest: airmastertapes
Overall: 17133
Online Now [81]:
Visitors: 80
Today: 13332
Total: 106677575
Forums › The Car › 206 Problems › Central Display Not Working
Go to page Previous  1, 2
kit325
PostPosted: Sun Oct 02, 2011 6:06 am Up
When u said it only works when u press on, is the backlight or the display pixel? Because ribbon only for the displaying pixel, while backlight problem will be cause by the small pin connection.
On the small connection pin socket, check on the soldering, see if there's any small tiny crack on the soldering?
kit
Chalky
PostPosted: Sun Oct 02, 2011 6:08 am Up
Yeah, like I say there's a few on eBay, in working condition, so will have to see if I can bid for one and get a bargain price!
...the piece on the circuit board isn't exactly solidly in place, there is some play. So I might have a crack at re-soldering it anyway and see if it makes a difference. If it still doesn't work I'll know it's the ribbon for sure.
Thanks for your help.
Deckchair5
PostPosted: Sun Oct 02, 2011 8:11 am Up
As the display works when you press on it then you may simply have poor contacts at the bulbs as they're not the best contacts in the world
Your display illumination won't be the same as this as this one is a single line display but you can get the idea of what to check for. This is how I cured this one with a dead illumination display
First of all check you have the right type of bulbholders. The two at the top of the picture are different types, the one on the left makes contact on the opposite side of the board to where you insert, the one on the right makes contact on the same side, they look similar and they both fit so beware
With all bulbs out, use a multimeter set on resistance to find out which pin of the connector supplies each side of the bulb circuit board tracks (On this one it was the middle two pins). Ok insert one bulb, now with your multimeter still set on resistance and touching those two pins then you should see the resistance of the bulb, around 10-20ohms, if not then you have a poor contact. Clean up the CB tracks carefully using an eraser or electrical contact cleaner and try again, you may even need to bend the bulb holder contacts. Once that bulb is done and making a sure contact then take that one out and do the others the same. Now you know all bulbs are going to work if they have voltage across them
micha3l19
PostPosted: Tue Jul 03, 2012 10:18 am Up
Hi, i also have problem with my display. I installed an aftermarket radio and now my display freezes. My display is the nr2 one.
Thanks for the help if anybody can help me Smile
michael
micha3l19
PostPosted: Thu Jul 05, 2012 2:42 pm Up
Problem resolved!
I just had to take out the set of the display wires and put it back in again Smile
michael
Page 2 of 2
