Latest: Puggingalong
Overall: 17129
Online Now [335]:
Visitors: 334
Today: 54271
Total: 101347188
Forums › The Car › 206 Problems › stiff gears
stiff gears
tommy87
PostPosted: Tue Jul 03, 2012 12:00 pm Up
hi im new to the 206 gti but i have owned a 205 gti befor
1.at the moment im finding it hard to move the gear stick in gos in to
gear fine but moving it around is difficult even in neutral
2.after about 5mins of diving it seams to be reving at 2000rpm on tick over
any ideas
GTI
Dillon
PostPosted: Tue Jul 03, 2012 12:03 pm Up
Staff - Dillon
Hello.
1. Check the linkages are greased
2. Clean the ICV
PostPosted: Tue Jul 03, 2012 1:03 pm Up
i would check the oil...
did you just buy the car?
tommy87
PostPosted: Tue Jul 03, 2012 1:07 pm Up
yes got it cuple of days ago . the gears seem to get harder as it warms up
GTI
PostPosted: Tue Jul 03, 2012 1:09 pm Up
did your clutch working fine?
tommy87
PostPosted: Tue Jul 03, 2012 1:11 pm Up
yes clutch is fine
GTI
PostPosted: Tue Jul 03, 2012 2:11 pm Up
does it make any different when the engine is off?
tommy87
PostPosted: Tue Jul 03, 2012 2:37 pm Up
dont think so its easy when its cold
GTI
PostPosted: Tue Jul 03, 2012 2:41 pm Up
Wrong oil in gearbox i'd say. Should 75w80.
PostPosted: Tue Jul 03, 2012 2:44 pm Up
if that's the case it should be the otherway round Confused
i would have though is more likely to be clutch issue (cylinder)
PostPosted: Tue Jul 03, 2012 2:59 pm Up
Im sure Edward had this problem when he put wrong oil in. Slave culinder would make it hard to engage gears, but not move the stick.
tommy87
PostPosted: Tue Jul 03, 2012 3:26 pm Up
even in neutral its stiff with out the clutch engaged
GTI
