Online Now [686]:
Visitors: 685
Today: 113948
Total: 145592967
Forums › The Car › 206 Problems › Torsion bar woes... Help!
kingofcatastrophe
PostPosted: Fri Jul 06, 2012 5:54 pm Up
So, the 180's been in my mates garage all day today, he managed to drop one side pretty quickly... but can't get the torsion bar out on the drivers side... and he's properly tried...
Any suggestions, people who've had and solved this problem...
Automotive Photographer.
swaynie
PostPosted: Fri Jul 06, 2012 6:09 pm Up
Plenty of wd40 or gt85 and a bigger hammer
Ps you have taken the lock washer out and cleaned all the grit out the way.
If your offended by my posts call\r\n0800 I dont care Wink
Uz
PostPosted: Sat Jul 07, 2012 2:38 am Up
Right if you can take the shocks out and then bolt a really long bar into place between the mounting points, from left to right (top and bottom) which will allow the trailing arms to stay in... getting them as tight as physically possible. You can actually smash ten folds of s**t out the bars just to get them out, obviously once you'd douzed them with a trade can of WD40, inside and out.
Only way we got them out the SW, but when we originally tried the right trailing arm was actually moving and it destroyed the bearing so those were replaced :/
Squeaker
PostPosted: Sat Jul 07, 2012 7:16 am Up
Not trying to knock them out the same way?
Don't they knock out opposite ways to eachother?
