Online Now [391]:
Visitors: 390
Today: 102849
Total: 142613176
Forums › The Car › 206 Talk › NGK vs Bosch spark plugs
PostPosted: Mon Jul 09, 2012 2:02 pm Up
Johnbyron wrote:
What's this code for then?? (what make plug??) FQR7ME
BOSCH
Johnbyron
PostPosted: Mon Jul 09, 2012 2:05 pm Up
Right so it's 7 not 6 nor 5 ?? Haha
My mate has the 5 bosch from halfords and he's currently found out he's running 3 cylinders in his 180 :'-)
PostPosted: Mon Jul 09, 2012 2:09 pm Up
Ahhhhhh what a shame Whistle...
Johnbyron
PostPosted: Mon Jul 09, 2012 2:14 pm Up
Are you trig to say I'm lying?? Haha because I'm not hes a member on here LeeMaddern Smile
Johnbyron
Are you trying to say I'm lying?? Haha because I'm not hes a member on here LeeMaddern Smile
PostPosted: Mon Jul 09, 2012 2:16 pm Up
I couldnt care less, fit the wrong spark plugs & as your mate has found out its caused damage to the engine.
Waste of time Bosch having a free technical website for people to use aint it Wink
I did post the link on page 1 of this thread.
Johnbyron
PostPosted: Mon Jul 09, 2012 2:24 pm Up
I used the link and it didn't give me a code for the gti 180 spark plugs (although I am on my iPhone and sometimes it doesn't show stuff up) Laughing
Anyway cars arn't built to run certain makes of plugs they are made to run certain specs of plugs I thought you'd of been smart enough to know that mr BSI Wink on every bike I've built I've set them up to run NGK platinum plugs because they were the longest lasting and can cope with the heat I was putting on them (12 heat) if the 180 is supposed to run 7's then mine was wrong in the first place because when I replaced mine the old ones were 5 and I never had any trouble but the ends did look a bit warped and my mates is running funny so five are obveously a big no no !! Smile
spike_202
PostPosted: Mon Jul 09, 2012 2:45 pm Up
I use bosh super 4s, replace them once a year usually when I do a full service
**spike's project**
TEAM:+200bhp
Lewis
PostPosted: Mon Jul 09, 2012 2:46 pm Up
why didn't you get Bosch super 4s as recommended?
Tivoli LX 1.1
Black GTI 180
White VXR Burg
PostPosted: Mon Jul 09, 2012 2:51 pm Up
Stick the NGK plugs in then & see what happens if you think you know better Wink
Im smart enough to follow the technical advice of PSA Peugeot / Citroen & not fit NGK spark plugs to one of there products due to the incompatibility NGK plugs cause with the coil packs phase detection system Whistle...
Im also smart enough to put the correct heat range spark plug in the engine as recommended by both PSA Peugeot / Citroen & the spark plug manufacturer Bosch.
You aint gonna listen to sense so just do what you want.
Johnbyron
PostPosted: Mon Jul 09, 2012 2:53 pm Up
Because in halfords the Bosch super fours wern't listed for the 180 they where only listed for the 137 engine I double checked the engine codes
PostPosted: Mon Jul 09, 2012 2:56 pm Up
Change the record, you have been given the Bosch spark plug code for the GTI 180 engine already & also the link to the Bosch automotive website to double check for yourself Rolling Eyes
spike_202
PostPosted: Mon Jul 09, 2012 2:57 pm Up
Sony get the 4s then get standard bosh they are just as good I took my ngk out when I 1st had my pug as it felt hesitant and juddery then did a service and put bosh in and was fine.
**spike's project**
TEAM:+200bhp
Johnbyron
PostPosted: Mon Jul 09, 2012 2:58 pm Up
Where do you get your information from mr BSI ?? How do you know NGK arnt to be used ?? I'm not saying your wrong I'm just wanting some clarification and yeah thatS the reason I didn't buy the super fours from halfords, because I know the 180 will need a higher heat rating than the 137, but I just thought it might be only one higher, turns out bosh recommend two hisher than the 5's Smile
Johnbyron
PostPosted: Mon Jul 09, 2012 3:02 pm Up
Okay I'll buy some fours and compare the two Over 6k miles each set just to satisfy people like myself Smile
Page 2 of 6
