Latest: jackrox1992
Overall: 17186
Online Now [369]:
Visitors: 367
Members: 1
Today: 113905
Total: 148486051
Forums › The Car › 206 Problems › Torsion beam torx nut rounded off :(
swaynie
PostPosted: Wed Jul 11, 2012 4:36 pm Up
Sad as per the title is there any tip on removal is it a drill and tap job
If your offended by my posts call\r\n0800 I dont care Wink
spike_202
PostPosted: Wed Jul 11, 2012 4:50 pm Up
Just chisel it to make a big wide slit in the end, then use a big flat head ect to turn it out or just drill and tap it out the thread will come out once the heads off I found.
**spike's project**
TEAM:+200bhp
swaynie
PostPosted: Wed Jul 11, 2012 5:29 pm Up
I may give it a shot it seems as though the last owner lowered the rear and over tightened the torsion bar bolts or used a whizzy gun bloody fools
imjeeves
PostPosted: Wed Jul 11, 2012 6:24 pm Up
That works well actually! Use heat as well if you can
PostPosted: Thu Jul 12, 2012 8:36 am Up
Chisel + hammer and patience usually works well Smile
PostPosted: Thu Jul 12, 2012 3:14 pm Up
I used a woodworking chisel to actually cut into the head and another knock and it came loose.
