Latest: jackrox1992
Overall: 17186
Online Now [796]:
Visitors: 795
Today: 250065
Total: 148767664
Forums › The Car › 206 Problems › Com2000 removal
Com2000 removal
adsayer
PostPosted: Thu Jul 12, 2012 8:29 am Up
Yo.
I have the airbag, steering wheel and cowling off. So I'm staring at a 'naked' com2000. I can't for the life of me work out how the com2000 actually comes off though!! Sad
I can't see any screws. I'm sat in the car crying (not really)
Help!!!
Ads Smile
southwestchap
PostPosted: Thu Jul 12, 2012 8:33 am Up
IIRC, mine had a jubilee clip on the 'column' that I had to undo toget it to slide off...was a while ago though...its was on a mux, 2002, 206.
PostPosted: Thu Jul 12, 2012 8:38 am Up
Undo the metal clamp on the back then release the plastic clips, it then slides of the steering column.
Make sure you disconnect all the electrical plugs on the back first!
adsayer
You sir, are a legend.
adsayer
PostPosted: Thu Jul 12, 2012 8:41 am Up
You sir, are also a legend.
adsayer
PostPosted: Thu Jul 12, 2012 9:24 am Up
Damn. I have an airbag fault??! Any ideas???
Ads
Cars: 03 206 Look 1.4 HDi & 02 206 Style 1.4 HDi
PostPosted: Thu Jul 12, 2012 9:32 am Up
Double check the 2 connector plugs are fully home in the drivers airbag before you clip in the yellow locking clips!
adsayer
PostPosted: Thu Jul 12, 2012 9:57 am Up
Will do.
'permanent fault. level of driver module level 2. Short circuit'
That's the fault code. Sounds ominous with the 'permenant' bit.
Just a few observations... The wires on the com2000 were white whereas the old ones were white. Visually it was different, speaker was located behind rather than in front.
Have I f****d it? Sad
PostPosted: Thu Jul 12, 2012 9:59 am Up
Permanent fault. level of driver module level 2. Short circuit
That doesnt sound good Confused
Where did this com2000 unit come from? did you see it working before buying it?
adsayer
PostPosted: Thu Jul 12, 2012 10:23 am Up
Nope. Came off a 2004 206 1.4 hdi, which had thr airbags deployed
Got another one coming tomorrow. I'll pop the old one back on, see if the fault corrects itself. If it does then great, if not then bad bad bad. Unless its a case of replacing the airbag or something.
Edit.
Took it apart again and now there's no light.
Mr BSI thanks for putting up with my endless simpleton question.
Oh and it doesn't have the button but I've just tried using the cocktail stick and I've got trip mpg stuff mega!
