Online Now [1360]:
Visitors: 1359
Today: 115249
Total: 149188928
Forums › The Car › 206 Problems › Upstream O2 Sensor on GTi180
raydc123
PostPosted: Fri Jul 13, 2012 7:56 am Up
Hi guys,
Can anyone shed some light on this for me? Any one have pictures?
Cheers
gti 180
PostPosted: Fri Jul 13, 2012 8:09 am Up
Its a sensor that sits in the exhaust between manifold and cat...
raydc123
PostPosted: Fri Jul 13, 2012 8:16 am Up
Sorry I did rush my question so rushed/sarcastic answer accepted Razz
I have had a quick look underneath but could not spot it, just looking for a picture to highlight where it actually sits and how to remove it.
Cheers,
gti 180
PostPosted: Fri Jul 13, 2012 8:24 am Up
I wasnt being sarcastic. There must be 12" of pipe between the cat and manifold...you might even be just about able to see it from the engine bay.
To remove it you need a lambda sensor socket. If the sensor is seized in the pipe the sockets can flex and open up losing grip of the sensor. Sometime a big spanner is best. If the sensor is going in the bin just cut the cables off it and stick a normal socket over it to remove. That wont slip off the sensor.
PostPosted: Fri Jul 13, 2012 8:28 am Up
I just use a normal spanner, never failed although sometimes a mallet helps on the spanner to loosen it up
raydc123
PostPosted: Fri Jul 13, 2012 8:46 am Up
Thanks, definitely cannot see through the engine bay the outlet manifold on these seem well hidden,
unless the car is raised properly in a garage I guess.
Cheers for your help guys.
gti 180
