Latest: cogeim7
Overall: 17185
Online Now [1059]:
Visitors: 1058
Today: 216726
Total: 147701941
Forums › The Car › 206 Talk › Do I have a problem? In fact, I have three questions
Forum Index › 206 Talk
Go to page Previous  1, 2
lee1985
PostPosted: Tue Jul 17, 2012 6:49 am Up
Thank you guys Smile How on earth can you tell? lol.
I think I need to take engineering/mechanics courses haha
No idea why people can do 60mph in like 3 seconds faster then!
Just out of curiosity I timed how long it taken to get from 70 to 80 in 5th gear - 4.5 seconds
Does that sound right?
Own a Blue Peugeot 206 GTI 180.
NICKST
PostPosted: Tue Jul 17, 2012 7:38 am Up
MrBSI wrote:
NICKST wrote:
Ngk plugs will kill performance.
Shhhhhhhhhhhhhhhhhh Whistle...
Smile
Ye defo a 180 like I said Ngk plugs in a 180 will kill performance this could be we're your problem is. U should be useing bosch super 4s.
How does it accelerate is it smooth power delivery constant up to about 4k then slightly picks up more about 4k?
And also official 0-60 times are done in perfect dry conditions with good tyres a new car and a experienced test driver.
PostPosted: Tue Jul 17, 2012 9:18 am Up
Barking wrote:
On the 'how do I know my car is a GTI 180' front - it has a 4-2-1 exhaust manifold which is easily seen at the front of the engine. That's probably the easiest visible thing (most other things are easily swapped to/from other 206's). Obviously an HPI check will also tell you what car you've got.
The 0-60 times - take the ESR off and it'll be quicker. Best time on my old 180 (54-plate) was 7.1 seconds. It's just practice to get it lower (and obviously a long enough private airstrip).
User manual - do you actually need one? It's a 206 - it will break down, but is easily fixed.
The exhaust manifold is not at the front, its at the rear on the gti lumps.
Abzynthe
PostPosted: Tue Jul 17, 2012 9:26 am Up
East Area Rep - Abzynthe
Its quite easy to tell really.
8v engines
16v engine - XSi
GTi
GTi 180
Johnbyron
PostPosted: Tue Jul 17, 2012 11:03 am Up
Lights normally do that Smile
Yeah you have a 180 so yeah rev it as high as you like It would be unlikely for it do go bang unless obveously if you sat on the rev limiter for ages which would be pointless haha
As for NGK plugs and 0-60 times, I have a 180 running NGK plugs and it hasn't "killed" my performance :'-) I still get 0-60 in about 7 seconds with traction control off Smile but I have yet to find out if the myth is true about NGK plugs nackering your coil pack and messing with the electrics etc
NICKST
PostPosted: Tue Jul 17, 2012 1:00 pm Up
It's not a myth mine had Ngks in it for 2years after buying it then decided to get genuine parts from Peugeot and did a service it was more responsive and seemed to rev better.
Peugeot wouldn't recommend and use them there selfs if the could use any old plug and save money.
PostPosted: Tue Jul 17, 2012 1:29 pm Up
But completely incorrect!
Barking
PostPosted: Tue Jul 17, 2012 1:36 pm Up
those 4 metal pipes at the front that go from the engine block. I presumed it was a 4-2-1, but not actually seen where they go.
What's wrong? The inlet manifold?
I got a dig bick.
You that read wrong.
You read that wrong too.
NICKST
PostPosted: Tue Jul 17, 2012 1:46 pm Up
He means you wrong because it's not a 4-2-1 manifold you can see at the front as its located at the back off the engine you can see the inlet manifold which is the reason it's connected to the tb and the airbox.
Barking
PostPosted: Tue Jul 17, 2012 1:58 pm Up
ah.ok. I was wrong - but it is the most obvious 180 engine feature, which is correct lol Wink
I got a dig bick.
NICKST
PostPosted: Tue Jul 17, 2012 2:20 pm Up
Tru lol
Page 2 of 2
