Online Now [72]:
Visitors: 71
Today: 73912
Total: 139004288
Forums › The Car › 206 Problems › Odd Locking problem (not bouncing locks for a change)
Evilbobbins
PostPosted: Wed Jul 18, 2012 9:02 am Up
Hi Guys,
I've searched around the forum for help with my central locking but I've not found anything that matches whats happening.
First off its on my 206 1.1 sport 2005 model 3 door
I am using the none remote key as I'm waiting to get a replacement sorted from the dealer.
Sometimes when I unlock the door all works fine but other times as soon as I unlock and open the door the boot and other door lock again, Then the system seems to disconnect the door that I unlocked from the rest of the central locking by this I mean once in the car dropping the locking pin and pulling it again does not affect the other door or boot like wise pressing the unlock button on the dash affects everything but the door I unlocked.
The only way I have found to get them in sync again is to pull the pin on the passenger door or unlock with the dash button then lock it with the pin on the drivers door after that its back to normal again.
The last time it did this (this morning) I tried locking the door with the key but when unlocking it stopped me unlocking the drivers door as if something was holding the locking pin down or as if the dead lock was stuck on.
So far I have put this down to using the none remote key but has anyone else had this problem and knows a fix or a cause to it?
Dave Smile
Deckchair5
PostPosted: Wed Jul 18, 2012 2:04 pm Up
Sounds like the driver's door lock is intermittently wrongly signalling that it's locked and the others are copying, as they should do
Again sounds like the driver's door lock is malfunctioning
Evilbobbins
PostPosted: Wed Jul 18, 2012 4:03 pm Up
You could be right with that, I'll try using the passenger door for a few days to see if that helps, once i get the remote key it may fix this problem Smile
Because that's how I roll...
Deckchair5
PostPosted: Thu Jul 19, 2012 4:48 am Up
I doubt it, I expect you'll either need to repair or replace the driver's door lock motor
Evilbobbins
PostPosted: Thu Jul 19, 2012 4:52 am Up
Thats cool, I looked through the paperwork and thats all covered by my warranty Smile
