Latest: jackrox1992
Overall: 17186
Online Now [1026]:
Visitors: 1025
Today: 46663
Total: 148813373
Project sleeper
Go to page Previous  1, 2, 3 ... 14, 15, 16 ... 85, 86, 87  Next
Brian
PostPosted: Wed Mar 17, 2010 7:49 pm Up
Trade Rating: +31
Yup, my 180 torque is 151lb/ft on the same RR. Ok the 180 already has slightly more uprated cams than the 138 but not by much. Tiz a funny kink, perhaps tha'ts where you're losing the "OOMPH" you're expecting?
Jamie
PostPosted: Wed Mar 17, 2010 8:18 pm Up
Very disheartening I must say seeing as I'm about to shell out for the conversion Sad
Maybe the cam choice was a bad one and you should have stayed with the fast road cams?
tRiCk
PostPosted: Wed Mar 17, 2010 8:28 pm Up
maybe you need to 1/4mile race a gti , 180 and then a type r (not the latest 1 theyr s**te) that will put a smile on your face if you win and you should win.
spike_202
PostPosted: Wed Mar 17, 2010 8:46 pm Up
lol at tirck remember.... 206 take over, my pug wips my mates type-R all day long hes power it way to far up the rev range and buy that time he hits it im long gone haha.
**spike's project**
TEAM:+200bhp
twed207
PostPosted: Thu Mar 18, 2010 2:00 am Up
abit sad to see that you're not 100% happy with it ed. Sad the setup does look the sex though! lol.
i'd say that those RR figures are bob on as all of the RR day's we've had at eccosse have been spot on and i've never heard of them tinkering with RR results. the operator is sound too, really nice guy. Smile
hope you get to the bottom of it. Wink
206 2.0HDi
My 207 WIP
Turbo Diesel Owners Club UK
L200 thread
macj
PostPosted: Thu Mar 18, 2010 2:03 am Up
look at the wheel drag between the two charts.... one is 30 odd HP and edwards is 50HP... someone is fiddling results
PostPosted: Thu Mar 18, 2010 2:43 am Up
The original print out on mine has 39bhp wheel drag! The car actually feels slower than it was at times. There is no sweet mid range torque at all and the only time it really shows benefit is really high up the rev range. I knew the power band would move further up the rev range but I did expect it to be stronger in the mid range too.
The whole experience of this conversion has been very negative and I actually regret spending the best part of £4.5k. If necessary I will share my experience and hopefully somebody will benefit and not get caught out like I did.
Seb
PostPosted: Thu Mar 18, 2010 3:35 am Up
Staff - Seb
I used to love rolling roads, thought it was great being able to see the power increases from what you did. Now I'd like to think I know better, and would go on exactly how the car feels, rather than some numbers on a piece of paper done by someone trying to sell you something.
If Edward says it doesn't feel as powerful as he'd expected, then perhaps it isn't Surprised
I don't think he'd lie about it, so either there is something wrong with the actual car, or maybe throttle bodies really don't give so much oomph.
Schumi
PostPosted: Thu Mar 18, 2010 5:24 am Up
Once iam glad to see complete. But. I suggest you buy a wideband. Mount it on car. Because I didnt like your power curve. Its co crackign (i cant find true word sorry my english). You have a real gold. Your gold is standalone ecu. I think your problem is your mapping. With a standalone your power curve must be smooth.
In example. Its my friends car. C2 VTS. Stock ecu, Stock DBW. PT52 cams. Thinker gasget (for little higher compression ratio) 106gti header, filter, exhaust. But Turkey best mappers make his mapping. And the resoults.
Install a wideband. Watch when full accelerate. After this disable your stock O2 sensor and connect wideband to ecu. Go for better mapper.
2005 206 RC RED
PostPosted: Thu Mar 18, 2010 5:28 am Up
It's running with an Omex ECU now.
Dave
PostPosted: Thu Mar 18, 2010 5:36 am Up
Are you not tempted to take it somewhere else like RS Tuning to get a check over and a 2nd opinion?
White Mk 5 Golf Gti
Quarmbo
PostPosted: Thu Mar 18, 2010 5:46 am Up
Or go back to Ecosse and explain why your not happy? Did they warn you/tell you to expect the power band to be higher in the revs? You've spent a lot of money on your car, they should recognise that and try and accomodate you as much as possible.
Ford SportGay-A
Jamie
PostPosted: Thu Mar 18, 2010 5:52 am Up
If you want a wideband sensor give Tour-de-Force (a subsidiary of RS tuning iirc) a ring, they had a huge batch in, and are selling them at £100.
Why have you changed to Omex? Is it the 600?
Seb
PostPosted: Thu Mar 18, 2010 6:32 am Up
Staff - Seb
Thing is even I noticed the difference in my 206. I went from a 1.4 to 1.6. With ph3 cams. The power band in the mid and low range honestly felt like it was still a 1.4 but over about 3250 rpm it got a little better, truly coming in at about 4000. Now that wasn't even a lairy cam. You can't get an amazing power band with higher spec cams throughout the whole range, it's just not possible.
PostPosted: Thu Mar 18, 2010 7:07 am Up
I did expect a flatter low rev output but i did expect the mid range to be better than it is. It seems to pull at 6k rpm like it used to at 4k rpm. The drop at 4k rpm isn't made up for by the improvement at 6k rpm.
Page 15 of 87
