Latest: Worthy967
Overall: 17143
Online Now [191]:
Visitors: 190
Today: 48652
Total: 115823517
Forums › The Car › 206 Problems › 206 Alarm
206 Alarm
ikasli
PostPosted: Fri Jul 20, 2012 8:32 pm Up
Hi Everyone,
I have tried searching for this problem, but couldn't find a solution so I thought I'd post a new topic.
My 2001 reg 206 alarm keeps going off. This occurs several times, day and night, and each time I check, there is nobody and nothing in sight.
Is there any way of decreasing the alarm sensitivity? Or is there a different problem with this? I am willing to do the work myself (if possible) especially, having seen how helpful and comprehensive replies on previous topics have been.
PostPosted: Sat Jul 21, 2012 2:04 am Up
Disable the ultrasonics before you arm the alarm system as a test.
Its the button next to the handbrake, ignition off, press & hold button till the red alarm light comes on & stays on, then lock the car with the remote fob.
You have to do this everytime you wish to are the alarm with the ultrasonics disabled.
9 times out of 10 its the ultrasonics that go paranoid & repeatedly trigger the alarm.
New set is cheap enough from Peugeot / Citroen & easy diy.
ikasli
PostPosted: Sun Jul 22, 2012 9:51 am Up
Thanks for the reply MrBSI. I tried to do what you said above but couldn't see a light turning on anywhere, so wasn't sure if I had done it or not!
After googling around what you said, I found that if you block the sensors with blu tack, it blocks the sensor. I tried it last night and it worked!!! Alarm didn't go off at all!
I'm assuming this means it actually is the ultrasonics which is faulty. Is there a way for me to tone down the sensitivity or replace it? If so, how much are the costs involved? As I said before, I'm quite happy to do things myself if possible.
PostPosted: Sun Jul 22, 2012 9:59 am Up
Replace is really the only option.
Peugeot / Citroen part number should be 6680 E9 - Alarm ultrasonic sensor £27.90 including the VAT from any Peugeot / Citroen main dealer parts department ( dont get ripped of on Ebay! )
One plug under the dash, cable then goes up the drivers A pillar to the first sensor then under the headlining to the second sensor.
Torx 10 & 20 screwdrivers needed to remove the sunvisors, A pillar trim is just clipped on.
The connector plug is a tight fit in the socket.
PostPosted: Sun Jul 22, 2012 10:12 am Up
I have some sensors that you can have for £7.50 delivered
