Posted: Tue Jul 17, 2012 4:41 am |
bought a new plug and seal from peugoet, come to tighten it up, and it tightens upto tight (maybe a tad tighter than tough tigh - if that makes any sense haha) but if tightened any more will become loose again
and i dont want to be driving along and have the plug become loose,
isit normal for the plug to be like this? if the above makes any sense at all
cheers in advance, neil
Posted: Tue Jul 17, 2012 4:42 am |
Sounds like a stripped thread OR incorrect sump plug.
What was the old sump plug like to remove? Does that tighten up ok?
Posted: Tue Jul 17, 2012 5:12 am |
the same, they both behave the same, i presume its MENT togo very tight and then no further?
Posted: Tue Jul 17, 2012 5:20 am |
you will need to rethread the sump then.
it suppose to hold tight. screw driver is more then enough to tighten the sump plug.
Posted: Tue Jul 17, 2012 5:25 am |
Sounds like the thread is stripped in the sump then.
You might be able to get a helicoil repair done on it BUT its a job for an expert / someone that knows what there doing!
Other then that its a new sump.
Posted: Tue Jul 17, 2012 5:40 am |
| MrBSI wrote: |
Other then that its a new sump. |
helicoil is easy to use
but ithough you need to take the sump off the car first?
Posted: Tue Jul 17, 2012 5:44 am |
| Seabook wrote: |
Only for some people
Posted: Sun Jul 22, 2012 10:47 am |
Sump repair. it can be done in situ (few will though) and it won't be cheap. Don't drive it like it is - well maybe to the garage and then watch the oil light very closely and stop immediately if the pressure drops or light comes on
Posted: Sun Jul 22, 2012 11:21 am |
rough estimated price on gettign a new sump & gasket fitted at a garage?
cheers in advance
found sumps at £30 delivered, + £10 for a new gasket
Posted: Sun Jul 22, 2012 11:25 am |
Why not do it yourself?
You need to call the garage that you will have the work done at.
It doesn't matter what anyone says on here unless they are doing the job.
Posted: Sun Jul 22, 2012 11:26 am |
Helps if we knew what engine it is
Posted: Sun Jul 22, 2012 11:32 am |
sorry the 1.6 xsi (tu5jp4??) I could do it myself but i have a lot on at the moment
Posted: Sun Jul 22, 2012 11:37 am |
Topics merged, there was no need for a seprate topic when you already have one open about the samething.
Posted: Sun Jul 22, 2012 11:40 am |
apologies
