Online Now [553]:
Visitors: 552
Today: 117215
Total: 145422931
Forums › The Car › 206 Problems › banging noise
banging noise
robclowes
PostPosted: Mon Jul 23, 2012 1:48 pm Up
I have a banging noise coming from drivers front. It mainly happens when i turn left. Had passenger lower arm done for mot and just had both dropbars done. Any ideas?
206 1.6 xsi
DeadEyePaul
PostPosted: Mon Jul 23, 2012 1:53 pm Up
possibly top mount bearings have died. get a friend to turn the steering wheel whilst you look at the suspension spring, if it is turning round its the bearing at the top
miller-94
PostPosted: Mon Jul 23, 2012 1:57 pm Up
Is it clunking or an actual bang? If its a clunk then its most likely the top mount bearing, I got mine replaced and the clunking stopped! The guy showed me the old one and it was completely shattered
robclowes
PostPosted: Mon Jul 23, 2012 2:11 pm Up
clunking. Will check tomorrow. Any ideas on price?
206 1.6 xsi
miller-94
PostPosted: Mon Jul 23, 2012 2:22 pm Up
Mine was £20 for each side then youve got labour (if your getting a mechanic to do it)
DanT
PostPosted: Mon Jul 23, 2012 4:24 pm Up
I'd guess top mount too, had similar thing on my old saxo, the actual top mount isnt usually very expensive (between 15-30 quid at a guess), but the labour to remove the strut and replace it does bump it up slightly if having it done at a garage.
