Latest: S2cgm
Overall: 17178
Online Now [572]:
Visitors: 571
Today: 137605
Total: 137667710
Forums › The Car › 206 Problems › Hazard light switch
Hazard light switch
Domo
PostPosted: Tue Jul 24, 2012 5:27 am Up
Hey guys is anyone in edinburgh area or would be able to help me. My hazard light seitch and clock have gone. Tey don't work and its my mot in a few weeks and obviously i need them for the mot. Anyone know whats wrong or a place i would be able to go to et it fixed that isnt too expensive as peugeot garages are ridiculously dear. Cheers.
PostPosted: Tue Jul 24, 2012 5:39 am Up
Year of car will be a big help
When you say clock, you mean the centre display?
Is it the hazard switch with the lock button?
Checked fuses? Changed stereo or messed behind dash recently?
PostPosted: Tue Jul 24, 2012 8:27 am Up
Your just p**sing in to the wind until you tell us what year of 206 you have.
there's 2 totally different electrical systems used on the 206 & the fuse boxes including fuse numbers are totaly different as well.
Domo
PostPosted: Tue Jul 24, 2012 10:22 am Up
1999 1.6 xsi. Central clock and hazard light button elow it. Yea messed bout with stereo and then it went don't no wat fuse cause i think it may b one has gone. Looked at the diagrams about them and cudnt figure it out.
Domo
PostPosted: Tue Jul 24, 2012 7:46 pm Up
when i lock my door with the fob the hazards still flash like they should so its not the lights
Domo
PostPosted: Wed Jul 25, 2012 1:52 pm Up
Sorry to keep postin in this but i want to get it sorted asap as ive left it too long already. Also im mearly at 50 posts Razz
Domo
PostPosted: Wed Jul 25, 2012 3:42 pm Up
Anyone got any more insight?
206boyracer
PostPosted: Wed Jul 25, 2012 4:12 pm Up
www.206info.co.uk/Foru...t=107.html
Use this to find your fuses and check with a multimeter. Not just by eye as sometimes they appear to be fine but are not.
Sound more like a fuse than anything else. Especially as you have been fiddling.
206 GTI 138.
Domo
PostPosted: Wed Jul 25, 2012 5:55 pm Up
Had seen that post before but i have no idea which fuse to check and how will i actually know if fuse is gone ( probs dumb question)
206boyracer
PostPosted: Wed Jul 25, 2012 6:40 pm Up
If you remove the fuse then set the multimeter to read continuity and put it across the prongs on the fuse it will beep or not. No beep means blown fuse. Double check it beeps first by touching both probes together. Failing that just replace the fuse anyway. Would imagine it will either be fuse F8 or F18. looking at the guide.
Sometimes if you look at a fuse from the back you can see that the metal strip in the middle has broken. If its a clear one you should be able to see from thd side. .
206 GTI 138.
Domo
PostPosted: Thu Jul 26, 2012 5:45 am Up
Ok another dumb question what/ where is the multimetre
Domo
PostPosted: Thu Jul 26, 2012 5:54 am Up
I just realised what multimetre is. I don't have one of them
Ill just replace the fuses and hope it works
PostPosted: Thu Jul 26, 2012 6:34 am Up
Save yourself unnecessary expense and ring an auto electrician to sort it.
I can see a dead 206 coming to the forum very soon.
Domo
PostPosted: Thu Jul 26, 2012 7:21 am Up
Thatll cost more than stickin few fuses in a fuse box. Sounds like a simple as hell job.
Domo
PostPosted: Thu Jul 26, 2012 9:12 am Up
Just looked at it car and tried figure out which fuse is which f8 is the one i thought needed to get chane tirns out its a diff one from all the rest so high chance it is.
